- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Problem with Digilent Spartan 3E-1600 and IMPACT
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-24-2010 02:20 PM
Dear all,
I am trying to program the Digilent Spartan 3E-1600 (XC3S1600E), using ISE Webpack 12.3 (M70.d) and iMPACT.
After successful synthesis and .bit file generation in ISE, I am able to initialize the chain and display the correct chain
(xc3s1600e -- xcf04s -- xcf04s -- xc2c64a).
After that, every command that tries to interact with the device fails.
For example, if I give the "Get Device ID" command, the following failure message appears in the console:
INFO:iMPACT - Current time: ��� 24. ��� 22Maximum TCK operating frequency for this device chain: 6000000. Validating chain... INFO:iMPACT:1206 - Instruction Capture = '1010101010101010101010110101000000010000000100000101' INFO:iMPACT:1207 - Expected Capture = '1010101010101010101010101001XXXXX001XXXXX001XXXXX X01' INFO:iMPACT:2129 - Boundary-scan chain test failed. Please check tdi->tdo connection between the cable and device:'1' ( 'xc3s1600e'). A problem may exist in the hardware configuration. Check that the cable, scan chain, and power connections are intact, that the specified scan chain configuration matches the actual hardware, and that the power supply is adequate and delivering the correct voltage. :15:07 2010 :11:08 2010 :59:57 2010 :58:48 2010
I have read related answers in the forum, e.g. I have tried to reduce the bitrate of the usb cable to its minimum value (750Khz), however that did not work as well.
I am looking preferrably for a software settings solution, i.e. I do not have equipment at hand to do signal debugging on the board etc.
Could the problem be associated with any device properties in my project. E.g. my target device is xc3s1600e-4fg320, i.e. Package FG320 with speed -4.
I would appreciate any input, thank you.
Re: Problem with Digilent Spartan 3E-1600 and IMPACT
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-25-2010 06:43 AM
Hi earthlink,
I am also trying unsuccessfully to program Digilent Spartan 3E-1600 (XC3S1600E), using ISE Webpack (12.2) and iMPACT.
But my error is different from yours.
Before trying to load '.bit' file, the iMPACT software doesn´t properly
recognize the FPGA on the board. The iMPACT failed when trying to
boundary scan.
To be honest, iMPACT failed on Boundary scanning because it wrongly identifies more than 30 'UNKNOWN' devices in the chain.
It appears a message: "There are many unknown devices being detected."
I
am using an USB cable to connect the pc to the on-board USB2 port(JTAG
programming). I am also using OS Windows7/64bits(6GB), but I tryied on
an OS WindowsXP/32bits(1GB) and got the same failure.
The console log shows the message:
Attempting to identify devices in the boundary-scan chain configuration...
INFO:iMPACT - Current time: qui 21. out 11:20:29 2010
// *** BATCH CMD : Identify -inferir
PROGRESS_START - Starting Operation.
Identifying chain contents...'0': : Manufacturer's ID = Xilinx xc2c64a, Version : 0
INFO:iMPACT:1777 -
Reading C:/Xilinx/12.1/ISE_DS/ISE/xbr/data/xc2c64a.bsd...
INFO:iMPACT:501 - '1': Added Device xc2c64a successfully.
'1': : Manufacturer's ID = Xilinx xcf04s, Version : 13
INFO:iMPACT:1777 -
Reading C:/Xilinx/12.1/ISE_DS/ISE/xcf/data/xcf04s.bsd...
INFO:iMPACT:501 - '1': Added Device xcf04s successfully.
'2': : Manufacturer's ID = Xilinx xcf04s, Version : 13
'3': : Manufacturer's ID = Unknown
INFO:iMPACT:501 - '1': Added Device UNKNOWN successfully.
'32': : Manufacturer's ID = Unknown
INFO:iMPACT - iMPACT quit the Identify Chain because it detects there are
at least 30 'UNKNOWN' type devices on the chain.
Please check the hardware settings and retry!
PROGRESS_END - End Operation.
Elapsed time = 119 sec.
I have already searched for a solution on Xilinx website but I didn't find any practical solution.
I tried to change the frequency operation of the USB cable, but it keeps the same error.
Earthlink, which usb cable are you using? How are the jumpers of your board configured?
Do you have already faced this problem before? Do you know a practical solution to solve this trouble?
Thanks for your attention,
Bruno
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-04-2010 10:44 AM
The impact software looks to find the the 2c64a and xcf04s on the board but not the other deivces.
Check the jumper settings on the board as well as the power. It would also be good to double check that the pod and software are functioning correctly with another board.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-20-2011 09:32 AM
Hi Bruno,
I am also getting the same error as you, so can you let me know how you got rid of the issue ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-02-2012 04:14 AM
Bruno, I have the same problem, I have lost a lot of time!!! Any solution?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-02-2012 04:15 AM
