- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
SENSOR- FPGA INTERFACE ERROR ..
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-09-2012 11:32 PM
Hi All !!!!!!!
I am using spartan 3 xc3s400 pq208 -5 device.
I have interface a distance sensor to one of the fpga channel and given external supply to sensor.....the distance sensor is working fine..
because when i check the sensor on dmm the voltage varies as per the distance varies....The problem is that variation in the voltage of sensor doesnot reflect the output which is given to spartan 3 board leds...
PLease help me regarding this!!!!!!!!!
Solved! Go to Solution.
Re: SENSOR- FPGA INTERFACE ERROR ..
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-10-2012 03:33 AM
Are you using a commercial development board, or are you using something you've developed?
Exactly how have you connected the sensor to the FPGA? Are you using an analog to digital converter? Which one? Are you sure you've configured it correctly? Have you simulated your code?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-12-2012 12:51 AM
Thanks for the reply Joelby......
1]No,its commercial development board...there is nothing which i have develop on board...........
2]Yes,the distance sensor has three terminal with 1]vcc, 2]gnd, 3]sensor output
i have given a supply of 5V to vcc and 0V to gnd from an adapter which directly connected to AC mains supply.only the sensor output pin is given to one of the input channel of FPGA board.
3]yes,i am using A to D converter from the IC 7891 which is
onboard of fpga kit.
4]I have seen the simulation its perfect ..........except with sensor interface........i have simulated for A to D vhdl code .
PLease help me regarding this !!!!!!!!!!!!!!!!!!!
[ Edited ]- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-12-2012 01:24 AM - edited 03-12-2012 01:26 AM
Please don't force us to guess which development board you are using!
Links to board schematics or product page would be handy as well.
And while you are preparing essential information, please include a link to the sensor datasheet.
-- Bob Elkind
Summary:
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-12-2012 02:53 AM
http://www.mte-india.com/ProductinfoNew.aspx?Produ
the above link give the details of the fpga board which i am using.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-12-2012 02:56 AM
This is an important step forward!
Do you have a specific sensor in mind?
-- Bob Elkind
Summary:
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-12-2012 04:40 AM
Hi All !!!!!!!!!!!!!!!!!
The attached file shows the distance sensor which i am using.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-12-2012 05:18 AM
You need to methodically check each part in the system. If you are using a commercial development board and an off-the-shelf sensor, there's a good chance that they work (unless they're damaged), which means that the problem is in your code 99% of the time. If it's working in simulation, you may not have simulated it properly.
Anyway, here are the steps I would take:
- Check sensor by connecting it to a multimeter or oscilloscope. Wave hand in front of it and check that the output matches the data sheet specifications.
- Check that the analog input for your FPGA development board is compatible with the output of the sensor. The MTE site has broken links, so it's not clear if the ADC has a pre-amplifier. Check the schematics. According to the sensor data sheet, the output voltage varies between 0 and 3.2 V. Is the ADC configured for single ended or differential input? What's its VREF? If VREF is 2.5 V, have you set the ADC's RANGE bit to 1 to allow input voltages of up to 2 * VREF?
- Examine the ADC configuration logic using a logic analyser or oscilloscope and verify against the data sheet that you're not sending it garbage.
- Consider implementing a configuration read-back stage to verify that the values you've set have actually made it to the chip.
- Provide a constant input voltage to the ADC using a voltage divider (e.g. a potentiometer), perhaps at the middle of the ADC input range. Observe the ADC's output using a logic analyser and confirm that the data values are what you would expect from the data sheet (for example, a 50% analog input value should give a digital output of 50% of the maximum value).
- Debug the FPGA's internal state using ChipScope Pro if you have a license, or using a UART or LED debug output if you don't. If you're just reading parallel data from the ADC and displaying that on LEDs, your internal logic ought to be incredibly simple, so there may not be many internal data paths to examine.
You might want to consider posting your code on the forum so that we can dissect it. Without it, we can only guess at what might be wrong and guide you to finding a solution (with it, we'll still try to guide you toward finding the solution yourself).
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-12-2012 05:37 AM
I have checked sensor on DMM its absolutely working fine...When power up the sensor,As the distance of opaque object changes make changes in the voltage level of Sensor also...
So I need to analyze my code.........
Thanks for the suggestion joelby.................
