Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
ajayvenkatesan
0
Virtex 7 IDELAY AND IDELAYCTRL INSTANTIATION
I have a preliminary design where I have a set of IDELAY modules along with one IDELAYCTRL instantiated in another module "TOP". Now this module "TOP" is instantiated 8 times in the design. I have defined a iodelay group for each instantiation of "TOP" which in this case is u_adc_port.
INST "u_adc_dac_tst/u_adc_interface/u_adc_port_0/U_33" IODELAY_GROUP = adc_1_port_0_grp;
INST "u_adc_dac_tst/u_adc_interface/u_adc_port_1/U_33" IODELAY_GROUP = adc_1_port_1_grp;
INST "u_adc_dac_tst/u_adc_interface/u_adc_port_2/U_33" IODELAY_GROUP = adc_1_port_2_grp;
INST "u_adc_dac_tst/u_adc_interface/u_adc_port_3/U_33" IODELAY_GROUP = adc_1_port_3_grp;
INST "u_adc_dac_tst1/u_adc_interface/u_adc_port_0/U_33" IODELAY_GROUP = adc_2_port_0_grp;
INST "u_adc_dac_tst1/u_adc_interface/u_adc_port_1/U_33" IODELAY_GROUP = adc_2_port_1_grp;
INST "u_adc_dac_tst1/u_adc_interface/u_adc_port_2/U_33" IODELAY_GROUP = adc_2_port_2_grp;
INST "u_adc_dac_tst1/u_adc_interface/u_adc_port_3/U_33" IODELAY_GROUP = adc_2_port_3_grp;
While running PAR for the design, the following are the errors the arise during the mapping phase:
map ERROR  MapLib:1114 - IDELAYCTRL symbol "u_adc_dac_tst1/u_adc_interface/u_adc_port_3/U_33" (output signal=<none>) has IODELAY_GROUP property "adc_2_port_3_grp". But the design does not contain DELAY element with the same IODELAY_GROUP name. New
map ERROR  MapLib:1114 - IDELAYCTRL symbol "u_adc_dac_tst1/u_adc_interface/u_adc_port_2/U_33" (output signal=<none>) has IODELAY_GROUP property "adc_2_port_2_grp". But the design does not contain DELAY element with the same IODELAY_GROUP name. New
map ERROR  MapLib:1114 - IDELAYCTRL symbol "u_adc_dac_tst1/u_adc_interface/u_adc_port_1/U_33" (output signal=<none>) has IODELAY_GROUP property "adc_2_port_1_grp". But the design does not contain DELAY element with the same IODELAY_GROUP name. New
map ERROR  MapLib:1114 - IDELAYCTRL symbol "u_adc_dac_tst1/u_adc_interface/u_adc_port_0/U_33" (output signal=<none>) has IODELAY_GROUP property "adc_2_port_0_grp". But the design does not contain DELAY element with the same IODELAY_GROUP name. New
map ERROR  MapLib:1114 - IDELAYCTRL symbol "u_adc_dac_tst/u_adc_interface/u_adc_port_3/U_33" (output signal=<none>) has IODELAY_GROUP property "adc_1_port_3_grp". But the design does not contain DELAY element with the same IODELAY_GROUP name. New
map ERROR  MapLib:1114 - IDELAYCTRL symbol "u_adc_dac_tst/u_adc_interface/u_adc_port_2/U_33" (output signal=<none>) has IODELAY_GROUP property "adc_1_port_2_grp". But the design does not contain DELAY element with the same IODELAY_GROUP name. New
map ERROR  MapLib:1114 - IDELAYCTRL symbol "u_adc_dac_tst/u_adc_interface/u_adc_port_1/U_33" (output signal=<none>) has IODELAY_GROUP property "adc_1_port_1_grp". But the design does not contain DELAY element with the same IODELAY_GROUP name. New
map ERROR
MapLib:1114 - IDELAYCTRL symbol "u_adc_dac_tst/u_adc_interface/u_adc_port_0/U_33" (output signal=<none>) has IODELAY_GROUP property "adc_1_port_0_grp". But the design does not contain DELAY element with the same IODELAY_GROUP name.
Can you tell me what I am doing wrong here. Also I would also like to know if I have to specify the group name just before instantiation of each IDELAYCTRL module in the design which is 8 times in my design. I have a hierarchical design with the module "TOP" containing instantiations of IDELAYCTRL and IDELAY modules and which is instantiated 8 times.
ywu
0
Re: Virtex 7 IDELAY AND IDELAYCTRL INSTANTIATION
You need to apply the same IODELAY_GROUP name on all IDELAYs assoiciated with a particular IDELAYCTRL.
ajayvenkatesan wrote:
map ERROR
Cheers,
Jim
ajayvenkatesan
0
Hi Jim,
Thanks for the reply. Could you let me know how do I put a different name for each IDELAY module associated with a particular IDELAYCTRL. Do I include it in the module which instantiates a bunch of IDELAY modules along with the associated IDELAYCTRL.
Ajay
ywu
0
I assume you have IDELAY's instantiated in each adc_port? If yes, you can set IODELAY_GROUP on them in UCF as well like below.
INST "u_adc_dac_tst/u_adc_interface/u_adc_port_0/U_idelay1" IODELAY_GROUP = adc_1_port_0_grp;
INST "u_adc_dac_tst/u_adc_interface/u_adc_port_0/U_idelay2" IODELAY_GROUP = adc_1_port_0_grp;
INST "u_adc_dac_tst/u_adc_interface/u_adc_port_0/U_idelay3" IODELAY_GROUP = adc_1_port_0_grp;
Hi Jim,
Ajay
Cheers,
Jim
davidhuo
0
Hi Jim,
Ajay
I met the same problem, but I use Vivado to PR, Should I set  the IODELAY GROUP in XDC?
davidhuo
0
In XDC file the command should be like this:
set_protperty IODELAY_GROUP IODELAY_MIG [get_cells u_adc_dac_tst/u_adc_interface/u_adc_port_0/U_idelay1]
set_protperty IODELAY_GROUP IODELAY_MIG [get_cells u_adc_dac_tst/u_adc_interface/u_adc_port_0/U_idelay2]
set_protperty IODELAY_GROUP IODELAY_MIG [get_cells u_adc_dac_tst/u_adc_interface/u_adc_port_0/U_idelay3]
