- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Anyone know what is HW_TIMEOUT =FALSE in a BIT file (ISE 10.1.3)?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-23-2008 12:00 AM
Since I use ISE 10.1.3 some projects have this string inside the BIT files, and I wonder where in the ISE environment it is set and what is it for.
Re: Anyone know what is HW_TIMEOUT =FALSE in a BIT file (ISE 10.1.3)?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-23-2008 05:38 AM
There is now a flag is added by bitgen to the programming file so iMPACT can tell if there are any HW eval cores (that would time-out after a certain period) so the user can be warned.
Maybe you generated the bitstream on a new computer without a valid license and didn't see the warnings.
Maybe you forgot to tell your coworker it was an eval bitstream - she/he likely want to know before trying to debug why the design quit working later.
bt
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-24-2008 03:59 AM
Thank you Timpe.
But I don't understand this:
- If I had HW cores in my design which require a license, bitgen should put the string HW_TIMEOUT=TRUE, isn't it?
I only use simple cores, like DPM's, comparators, FIFO's or Shift Registers.
Anyway, thanks for your answer.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-24-2008 05:47 AM
I would expect the parameter to be TRUE only if you used any licensed cores that were in HW Eval mode.
Otherwise (no licensed cores or licensed cores with a full hardware license), I would expect it to be FALSE.
bt
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-14-2011 10:28 PM
so... I want to ask how i can remove it (I need it because I have a script that passes the file and reads out all kinds of data and i do not that this information will be there)
