Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
cepasp
0
ERROR: Failed to create the command line for XST. One or more procedures reported errors.
I am getting this error for unknown reasons, and I am having a difficult time debugging it.  Normally I would turn on logging for the xst step by going into design utilities but this doesn't work because xst hasn't even run.
Is there any way to get a log of what it is ATTEMPTING to run, so I can figure out if it's some kind of permissions or path problem?
This is WebPack 9.2.04i on Windows XP, with everything installed in the correct place.  It worked for a while, but some time between yesterday and today something must have changed.
--Chris
Expert Contributor
gszakacs
0
Re: ERROR: Failed to create the command line for XST. One or more procedures reported errors.
This is a shot in the dark, but do you perhaps run AVG antivirus?  see thread:
http://forums.xilinx.com/xlnx/board/message?board.id=ISE&message.id=1209&query.id=20582#M1209
Gabor
-- Gabor
barayschuk
0
I got this error when my project had two files with same name. One file for synthesis, other for simulation. The project was successfully synthesized after removing file for simulation.
-- Vasiliy
infinition
0
[ Edited ]
Hum... I just got this error... My project was working fine until now. Can you give me an exemple of the duplicated files? I mean, where did you found your answer?
EDIT: I don't have AVG by the way.
Message Edited by infinition on 02-04-2008 02:16 PM
infinition
0
Ok, I found it. I don't know which file was the problem, but I deleted all the auto-generated files in my work folder and re-executed the process and now everything is back to normal.
cepasp
0
Where were these files?  Obviously you can't ahve two files with the same name in the same directory.  Or do you mean in the Project?
hamsikam
0
I could resolve the same error by turning off the ISE and starting again.
