Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
jhissem
0
ISE Simulation not showing all outputs
after running the simulation, i found that one of my outputs was missing.  any ideas on what is causing this or how to fix it?
duthv
0
Re: ISE Simulation not showing all outputs
In order for anyone to help you should provide more data. Such as is the output missing from the waveform top level? That means you need to manually add it?
Or is it that the output is shown on the waveform, although none of the transitions are appearing? What is the exact issue you are seeing?
Also please clarify the simulator. I am guessing you are referring to the simulator build into ISE correct?
Duth
jhissem
0
the test bench waveform shows 5 outputs, which is correct.  When I run the built in simulator, the results only show 4.
duthv
0
Which version of SW is this? Do you see the output in the objects window? Is it just that in initial run it is missing can you add it in manually?
-Duth
xeeesh
0
salam...
   I m facing exactly same problm ... plzzzzzz  do help if u got d idea?????
Super Contributor
rourabpaul
0
1st of all go to 'project' option and click 'clean up all genarated file file' and try it again. If you u facing same problem, then creat an new project for your code. I think its a bug of ISE.
Research Fellow
University of Calcutta, India
