Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
0
View HDL Source & Instantiat ion Template Not Working
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-12-2008 04:37 AM
Has anyone every noticed after creating a CoreGen block (in this case a DCM) that after the .xaw file is created, you want to instance the DCM in your VHDL so double click on the View HDL Source or Instantiation Template and nothing happens? I say nothing happens, the blue "busy" wheel turns a bit, the mouse pointer flashes to a timer a few times and nothing happens. So right click either of these and it says that the process is still busy. On other IP cores (like FIFOs) it also does not work but if you look in the project directory, there is a .vhd file there that you can rip off.
I get this sometimes when flipping between ModelSim pre and post layout simulations (where the only fix is to "cleanup" the project). Really annoying - after 1hr of trying, I still cannot infer the DCM I made in 5s in CoreGen......
0
Re: View HDL Source & Instantiat ion Template Not Working
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-18-2008 07:59 PM
i encounter a same problem in viterx-II,and the fact is it doesn't generate the vhd and vhi source file . It is a bug .
0
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-20-2008 05:23 AM
Can you check if the .xaw is actually generated ?
If it is then please file a webcase with the files.
Hemasunder.
0
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-21-2011 03:11 AM
Was addressed?
I'm using a virtex II pro and so I've to use ISE 10.1 (sp3) but I've the same problem.
Is there a fix?
Is there a fix?
