Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Contributor
vohaid
0
Accepted Solution
How to reset CPLD?
[ Edited ]
This quite a beginner's question but I have not been able to figure out how to reset my CPLD (XC95288XL-10-FG256).  Researching this function pointed me to set the GSR in one of two ways: Check the option in the Fit properties or specifically define it in the UCF constraints.  After trying both way, I still cannot get my device to reset when I press the reset button.  Despite checking the "Use Global Set/Reset" check box in the ISE Fit properties, the Fitter report says the following:
** Global Control Resources **
Signal 'Clk' mapped onto global clock net GCK1.
Global output enable net(s) unused.
Global set/reset net(s) unused.                                                 <-------------  Still say unused
Here is a snippet of my VHDL code:
entity TopLevel is
    Port(
        Clk                     : in  std_logic;                                    -- Clk input 20MHz, 50ns period
        PWM_In            : in  std_logic;                                    -- PWM input active low
        Reset                 : in  std_logic;                                   -- CPLD GSR input
        Out                    : out std_logic
end TopLevel;
UCF contraints
Net   "Clk"          LOC = "M2";
Net  "PWM_In"  LOC = "D1";
Net "Reset"        LOC = "C4"  |  BUFG  = SR;
Net "Out"            LOC = "B5";
Am I doing something wrong?
Please advise
Best Regards
HV
Expert Contributor
robinliuy
0
Re: How to reset CPLD?
Check if Reset is used as a set/reset signal in your code. Also check if there is information in report that Reset is optimized.
ayang
0
A common misconception is that even though the signal is a 'global set/reset' -- it is NOT automatically tied to all registers in the design. You still must connect the reset signal to the registers that you wish to be reset by that pin. The 'global' refers to dedicated routing that is available for this signal. I suspect you may not be making this connection, and that is why it is listed as 'unused' in the report file.
/Arthur
