- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: XC2C32A CPLD long Configurat ion time
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-11-2012 09:31 AM
a
I'm not trying to use it as a registered pin. The VHDL code is
tp_out <= '0';
Is there a specific report / file which would give a positive indication what the compiler/fitter has done so I can give you a better answer?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-11-2012 12:18 PM
Update on some tests I have done today.
I retargeted the code to an eval board for Xc2c256 (the cool 'X' shaped pcb CoolRunner-II Starter Kit). The long "configuration" time was NOT observed. The retargeting involved writing a new .ucf file and changing the target device, so I'm fairly confident now that the VHDL/synthesis/fit process is producing what I was expecting (tp_out <='0').
Back to my board.
I looked further at the tp_out pin during this long configuration time. The period is 1.7 seconds, and it appears to be high-z with a weak pull up during this time.
I powered the device with only the Vccint (Vccio off). I saw the output rise to 1.8v for approximately 1.7 sec before going to 0V.
I tied TMS, TCK, and TDI to Vccio, there was no change in the startup behavior.
I've read the excellent "XAPP440 Power On Behavior of Xilinx CPLD's". Lots of great insight into what is going on in the chip!
Still no success in changing the behavior with the long config time. Any ideas are welcome! (does that sound too much like begging?)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-11-2012 02:00 PM
I have asked the question to someone here who should know,
I will post back when I get an answer....
Principal Engineer
Xilinx San Jose
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-11-2012 02:36 PM
"VCCINT rise time is a natural. Stalling in the neighborhood of 1-1.2V where it's open to noise might ne something to look at. Frequently hanging a scope probe on VCCINT makes it go away suggesting insufficient Decoupling."
Try looking at how the Vccint rises....
Principal Engineer
Xilinx San Jose
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-11-2012 02:48 PM
Mike,
Very curious issue!
I am assuming that none of the other IOs are working until this ~1.7 delay after power-up, correct ? Or is it just this tp_out that isn't working?
Archive the project and attach it to your next post. I can take a quick look at it to see if there's any hints in the fitter report.
Also are you scoping VccInt at the CPLD pin (as opposed to the output of the regulator - wherever that may be) ?
/Arthur
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-11-2012 04:22 PM
Austin
I looked at Vccint rise times. I saw the plateau you referred to
with an external power supply located about 2ft away I observed the following at the chip.
1) a very fast rise to 375mV, <10usec
2) a monotonic rise from there to 1.00V occurring over 1.6msec.
3) a plateau from 1.00V to 1.40V over 1.6msec
4) a rapid rise to 1.8V over 420usec
In the design have a 10uF ceramic about 1in away. I added a 0.1uF ceramic about 80 mils from the part. This did not change the 1.7sec configuration time.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-11-2012 04:32 PM
ayang wrote:
Mike,
Very curious issue!
/Arthur
Arthur the delay is seen on all output pins, not just the tp_out pin.
I am scoping about 50-100mils from the part. I am using a Very old scope, HP54501. I think it was one of the first digitals out in the early 1980's. Fast transients on Vccio won't be captured.
See attached for the latest files to build, I am building the x6_1a.jed file, ignore other targets.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-11-2012 05:00 PM
If the delayed output behavior is on all outputs, then it's not anything in the design itself that is the problem.
I looked at your makefile and it looks like you are using some sort of Digilent software to do the CPLD programming. Is this a Digilent board? I am guessing you are using a Digilent programming cable as well. Depending on what sort of programming cable that you have, the Xilinx iMPACT programming software may support it. I suggest you try using that to program the CPLD instead of the Digilent tools. My mind is fuzzy on this, but there are additional bits that need to be programmed that aren't in the Jedec file, and if the Digilent tools aren't programming them properly, it could hold off self configuration.
/Arthur
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-12-2012 06:38 AM
I'm out of the office today, but I'll give the Impact software a shot when I get in tomorrow.
Any special settings needed for the Impact tool to set these special bits?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-12-2012 02:00 PM
Nope, these bits will be programmed properly by iMPACT automagically. =)
/Arthur
