Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
mcrowe@gcdataconcepts.com
0
Re: XC2C32A CPLD long Configuration time
Awesome fix!    Thanks.
Using Impact programming tool with Digilent programmer does the trick!
The time "tp_out"  remains High Z is now 1.8msec!
Now, how to go forward?
The Xilinx impact tool, while nice in an engineering environment, doesn't work in our production line which is basically a script with go/no-go response, so I either need to get a fix that works with the Digilent software or find another programming solution.  In the plethora of ./bin/ files supplied by Xilinx is there a command line tool that might work?  Other third party tools?
I assume that the bits you are referring to are the ISC done bits?  Is there a reference document describing how to deal this these bits?   I'll be contacting Digilent with this so see if they can be persuaded to apply a fix.  It would be nice to have some supporting documentation to give them.
Thanks to everyone who helped out with this!
Mike
0
I think I found the reference document "CoolRunner-II Programmer Qualification Specification"
ayang
0
[ Edited ]
The unspecified bits are the 'transfer bits' and the 'done' bit -- they all need to be programmed properly.
iMPACT can be run in a script mode.
impact -batch whatever.txt
whatever.txt is the commands that you want iMPACT to run
I expect it to look something like this
setmode -bs
setcable -port auto
identify
program -p 1 -e -v myfile.jed
In the iMPACT help, there is a section on batch commands so you can find more info there.
/Arthur
0
Awesome!
The exact install.txt file format (more verbose than needed) was this
setMode -bs
setCable -target "digilent_plugin"
identify
assignFile -position 1 -file x6_1a.jed
erase -position 1
program -position 1 -verify
identify
closeCable
deleteDevice -all
exit
And the syntax for impact was
/opt/Xilinx/13.4/ISE_DS/ISE/bin/lin64/impact -batch install.txt
I had some problems with the older version of the Digilent runtime software (seg fault on exit), but they released a new version recently ant that seems to have cleared up that issue.
Thanks for helping me get back into production mode!
Mike
