Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Contributor
forte31
0
Accepted Solution
XC9500 Clock requirements
I can't seem to find the Global Clk input risetime requirement in the datasheet. Is there another document I should use?
Expert Contributor
gszakacs
Re: XC9500 Clock requirements
A quick site search for "rise time" got me to this answer record:
http://www.xilinx.com/support/answers/3226.htm
They're pretty loosey goosey about specifying rise and fall times.  Although they
say you can use a slower edge than recommended if it is "monotonic" you have to
watch out, because they mean "monotonic at the internal pad of the part" which may
differ from the pin if you have significant ground or power noise.
-- Gabor
-- Gabor
Regular Contributor
forte31
0
Thanks gszakacs. I wish there was a more formal document i could use to show my management. I inherited a design using a 555 timer as a system clock. I have to assume this will cause problems as explained in the answer record.
Expert Contributor
eteam00
0
Fortunately, I had already set down my mug of coffee before I read this.  These are no doubt the funniest words I will read or hear all day long.  Is this a limited run of circuits, where you can jerry-rig a proper (schmitt trigger) buffer into the circuit?
Or perhaps you have an extra pin or two on the CPLD, to form your own R-C oscillator?
-- Bob Elkind
SIGNATURE:
Summary:
Expert Contributor
gszakacs
0
If you need more weight behind the answer, I would suggest talking to your Xilinx sales rep
or FAE.  As far as the 555 timer goes, I believe there are quite a few flavors of this part and
you might find one with better rise and fall times.  I must say though that it's been about
30 years since the last time I used one in a design.  I consider these to be more of a "hobbyist"
part.  I don't remember if its output is active drive or open collector.  If it's open collector, you
can always reduce the pullup resistance to get a faster rise time, but that would of course
eat more power.  If all you really need is a cheap and dirty RC oscillator, then you might look
at any number of CMOS inverting Schmitt triggers that have very good rise and fall time characteristics,
although the thresholds do not have the same precision as the 555 timer, so you'd need to
tweak the R and C values.  If you plan to build more than a handful of these designs, then
you should probably look into other clock sources.  There have been a lot of advances in
timing generation since the 555 timer.  You can buy a PIC micro in an SOT-23 package that
has an internal clock with 1% accuracy, and just program it to toggle an output.  It needs no
external timing components, and costs much less than $1 in small quantities.
-- Gabor
-- Gabor
Expert Contributor
eteam00
0
555 timer lives!
[ Edited ]
As a followup to Gabor's comments...
The National (now TI) LMC555 has a datasheet rise/fall time of 15nS (typical).  There is no min/max spec.  This is a considerable improvement over the 100nS (typical) spec of the classic LM555.
The Philips (now NXP) folks have an improved ICM7555 part with a breathtaking 75nS (typical) rise/fall spec.
But seriously, it only takes one additional CPLD output pin to provide (more) hysteresis on the CPLD's clock input pin.  This should be sufficient, and a circuit simulation with the CPLD IBIS models should provide the solid data needed to convince a crusty old manager.
-- Bob Elkind
SIGNATURE:
Summary:
Regular Contributor
forte31
0
Thanks to all. I personally have been using the LTC6905 (0.5ns risetime). I will try to convince my management for a re-design. I know they will ask for the risetime requirement for the XC9500. I will use the answer record.
Regular Contributor
forte31
0
Re: 555 timer lives!
The hysterisis approach is a good suggestion too, thanks.
Expert Contributor
eteam00
0
[ Edited ]
If you can do a board turn, a proper clock source is much better than a two-pin hysteresis circuit.
Keep in mind that the LM555 runs up to about 1MHz before it super-novas into the circuit board.  Check the frequency range of the LTC6905 series.  You don't want to melt the poor CPLD with 100x clock frequency.
Maxim has an assortment of low-frequency (under 1MHz) oscillators ("silicon oscillators") which are less expensive than the LTC6905 parts.  The DS1099 is available in frequencies in the range that an LM555 might be comfortable.
Good luck to ya!
-- Bob Elkind
SIGNATURE:
Summary:
Regular Contributor
forte31
0
But the DS1099 has a 20ns risetime exceeding the PLD 10ns max.
