Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
mbla103
0
Ethernet 1000BASE-X PCS/PMA or SGMII on sp605
Hello Xilinx Community :)
I am a university student studying Mechatronics Engineering and I have  recently been given a job at a small high frequency trading company. My long term task is to improve performance of the intake of market data using an fpga. The intake method into the fpga is via ethernet and from the fpga to the computer is via PCIe.
I am starting off small, with an sp605 dev board to get started. I have decided to start off with the ethernet side of things and once I get something working, go onto PCIe. I have been working on this for about a month now, slowly learning more and more about Xilinx tools, verilog, ethernet protocol, IP cores etc. My previous experience with fpga's was just one digital circuitry paper at university, which involved the use of verilog, creating a simple calculator on an (alterra) board. So most of this stuff is new to me.
I started off by ripping apart the Base Reference Design for the board and extracting all the things that have to do with ethernet (ethernet MAC, mdio interface etc) in an attempt to try make my own project/design. The goal is to simply receive data and light up the LED's on the board with the receiving stream. I managed to get the ethernet lights next to the ethernet port blinking when i send it some data, and managed to obtain a link speed. But i did not manage to receive any visible data.
The approach im taking now is to use the free Ethernet 1000BASE-X PCS/PMA or SGMII core to receive data which seemed to be a simple solution. I tried setting up the core in SGMII mode to create the SGMII to GMII bridge. I have tried to configure the core with the mdio/auto negotiation and hook it up to the MAC i took from the BRD design. With this the status vector shows me that i am receiving invalid data and that the data received is not in the look up tables (at least im getting some sort of feedback).
I also tried configuring the core without the mdio interface or auto negotiation, but with this i get no feedback from the status vector. I have been going through the core user guide and datasheet, following what it tells me to do (e.g. tie the signal detect high, set the configuration vector properly). However I cannot manage to establish a link, and I have run out of ideas. I am using the example design it provides and integrating into it.
Am I missing something fundamental? Do I have to connect some things to the FPGA PHY pins (e.g. PHY_RXD[7:0]) or make any other constraints in the UCF? I am expecting to receive incoming data from the core and simply displaying it on the LED's as it comes in. Is this expecting too much?
Any advice on simple steps to use this core/cores in general would be appreciated.
Thank you
Mario
p.s. I'm using this ethernet packet generator to send the board packets directly from my computer: http://eth.cyberine.com/
Expert Contributor
rcingham
0
Re: Ethernet 1000BASE-X PCS/PMA or SGMII on sp605
There is quite a lot of activity in this field at the moment, and most of it is highly proprietory as every company wants to steal a march on its rivals. The companies that seriously want to succeed are recruiting well-experienced networking engineers and FPGA designers.
mbla103
0
This is a long term project for a small company so I am looking to learn and become experienced. Can you/anyone help me out with getting this core example design running?
I think the problem might be with configuring the GTP transceivers. RIght now I am simply adding the GTP wizard .v files into my project as they are instantiated. Is this all that is required? And why does the example design bring txp0, txn0, rxp0 etc to the top module?
Expert Contributor
sushantm
0
Just generate 1 example design from coregen with 1000 Base-X or SGMII as interface.
You have to take the complete emac block from the example design along with GTP Tranceivers.
TXP/N,RXP/N are differential signals through which GTP will communicate outside the FPGA.
GTP converts this single bit differential signal into parllel 8 bit data & vice versa.
Also I suppose you should be aware of MGT clock if you are using GTP Transceiver.
Just try to run simple example design with address swap module.
I can help you in this regard.
--Sushant Mahajan
Signature:
1.Have you ever tried typing your question into Google? If not you should before posting.
2.Read the datasheet and user guide. Have you read the user guide in detail ? Can you find the user guide?
3. Search the forums for similar topics.
4.I have neither found any similar thread in existing forum nor web-search is helpful to me.What should I do ?
Post your issue in detail comprehensive format on the relevant
forum.
5. Do not post the same question on multiple forums,please search and post it on relevant forum.
6. Do not raise a new topic or question on someone else's thread, start a new thread!
7. Students/Newbies: Copying code is not the same as learning to design.
8. "It does not work" is not a question which can be answered. Provide much details (with webaddress, datasheet links,etc..).
and make sure to be specific!
9. You are not charged extra fees for comments in your code,It will help others to understand well.
10.If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
