Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Expert Contributor
golson
0
XAPP1014 Looking for VHDL or Verilog File
  I am looking at the GTX demo example and would like to simulate this Demo.  Unfortunately, the DRU file is only available as
a ngc file with a verilog wrapper.   This makes it impossible to use a NON ISM simulator.  Is there a Verilog and/or VHDL file available?
Thank You,
  Gary
bwiec
0
Re: XAPP1014 Looking for VHDL or Verilog File
Can you use netgen on the ngc to create a sim model?
www.xilinx.com
Expert Contributor
golson
0
  This is something I did not know about.  How do you use Netgen?  Can I create a VHDL or Verilog file that might be synthesizable also so I could get rid of the ngc file.
Thank You,
  Gary
bwiec
0
Hi Gary,
Yeah, you can use netgen to generate simulation models. See the Command Line Tools User guide for more info (UG628).
In short, I usually use:
netgen -sim -ofmt vhdl <netlist_name>.ngc <output_name>.vhd
or
netgen -sim -ofmt verilog <netlist_name>.ngc <output_name>.v
That's from memory though, so I might have missed something!
No, netgen us really used for generating simulation models from NGC files, not synthesizable code.
www.xilinx.com
Expert Contributor
golson
0
[ Edited ]
Hi Bwiec,
  Your command does work.  The file being a .ngc file is a simulation file.  I guess that means this ngc models the behavior of the GTX recover Data Logic. for simulation purposes only.
The result of Netgen produces verilog and VHDL files that are encrypted.
My Simulator can not read the encrypted file.  Am I stuck,  I am using the Aldec Simulator.  Would ISIM work with this file or
Modelsim.
Thank You,
   Gary
