Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Visitor
weilings
0
Accepted Solution
A simple question
I am just a beginner of System Generator user,and when I want to get started with this tool, I come with this problem:
Error reported by S-function 'sysgen' in 'gateway_in_out/Gateway Out':
An internal error occurred in the Xilinx Blockset Library.
Please report this error to Xilinx (http://support.xilinx.com), in as much detail as possible. You may also find immediate help in the Answers Database and other online resources at http://support.xilinx.com.
Since it is possible that this internal error resulted from an unhandled usage error in your design, we advise you to carefully check the usage of the block reporting the internal error. If errors persist, we recommend that you restart MATLAB.
Error reported by S-function 'sysgen' in 'gateway_in_out/Gateway In':
the system I want to build is show in the picture below!
Super Contributor
vlavruhin
0
Re: A simple question
Hi.
Please make sure that you are using compatible versions of MATLAB and System Generator:
http://www.xilinx.com/support/answers/17966.htm
Also are you executing System Generator from Xilinx folder in Start menu or MATLAB? You should run System Generator.
Best Regards,
Vitaly.
Regular Visitor
weilings
0
I got it , I restart the Matlab and ... wala...Thank you very much~
Sometimes the simulink is a very subtle thing ....
