Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
wangsf1112
0
Hardware co-simulation question
hi,
  when i using hardware co-simulation  shared memory(FIFO),there is a errer:
Could not create shared memory. A shared memory with the name "BA_pipe" is already in use.
This could be because another System Generator block is executing that is set to "own and initailize" a memory of this name. If you are using System Generator's shared memory C++ API directly, it could also be because you have started another process that has created a memory with this name.
Error occurred during "Simulation Initialization".
I don't know how to deal, so need help, please
Super Contributor
vlavruhin
0
Re: Hardware co-simulation question
Could you provide more information about this issue and your project?
Best Regards,
Vitaly.
wangsf1112
0
OK,thanks.    when I use the "From FIFO" and "To FIFO"module in hardware co-simulation design,there is above-mentioned error. Even only use these modules,the error occured similarly.
Super Contributor
vlavruhin
0
Is computer-based simulation of the model running without errors? Could you attach simplest project that produces that error?
Best Regards,
Vitaly.
wangsf1112
0
the error occur when computer-based simulation of the model running. and when I use a simplest project ,the error is same.
Super Contributor
vlavruhin
0
Ok, that means the problem isn't connected with hardware co-simulation. But could you show us your project? It's hard to tell what's wrong without having look at the model.
Best Regards,
Vitaly.
wangsf1112
0
OK, the simple project is in the attachment.
 thank you.
Super Contributor
vlavruhin
'To FIFO' and 'From FIFO' blocks are supposed to have same shared memory, right? And that's why they have same name.
But this shared memory space should be instantiated only in one block.
Look at the properties of these blocks. There is an option 'Ownership'. Set it to 'Locally owned' at one block (for example, 'To FIFO') and set it to 'Owned elsewhere' at other block (i.e., 'From FIFO').
Best Regards,
Vitaly.
wangsf1112
0
thank you for your help, but there is a new problem :
Attempted to write to the fifo while it is in a reset state. The fifo requires three cycles at startup to initialize.
Error occurred during "Simulation Update State".
wangsf1112
0
I kown it, thank you very much!
