Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
pguillem
0
Problem with 20log10 LUT in Mcode
I'm trying to implement a lookup table in mcode.  The intent is to provide a 23 bit number, compare it to some decision boundary values, then provide a decibel value between -128 and 0 dB.
I've attached my current attempt to this post.
I'm not sure what I'm doing wrong in the code.  When I try to update my design, I get some unknown internal error.
If someone could help me, I'd really appreciate it.  My implementation is intended to allow for fast clock speeds.  I'm more of a systems guy than an FPGA expert, so I may have made some error in this attempt.
If anyone can help, I'd be very grateful.
BR,
Phil
P.S.  My tool versions are the following:
MATLAB Version 7.3.0.267 (R2006b)
Operating System: Microsoft Windows XP Version 5.1 (Build 2600: Service Pack 3)
Java VM Version: Java 1.5.0 with Sun Microsystems Inc. Java HotSpot(TM) Client VM mixed mode
MATLAB                                                Version 7.3        (R2006b)
Simulink                                              Version 6.5        (R2006b)
Communications Blockset                               Version 3.4        (R2006b)
Communications Toolbox                                Version 3.4        (R2006b)
Filter Design Toolbox                                 Version 4.0        (R2006b)
Fixed-Point Toolbox                                   Version 1.5        (R2006b)
Signal Processing Blockset                            Version 6.4        (R2006b)
Signal Processing Toolbox                             Version 6.6        (R2006b)
Simulink Fixed Point                                  Version 5.3        (R2006b)
Xilinx System Generator                               Version 9.1.01     production build
nathanx
0
Re: Problem with 20log10 LUT in Mcode
Check AR http://www.xilinx.com/support/answers/17966.htm, if it is the internal error, try another model to see if the error is specific to the model you are currently using. If the issue not related to any specific model, then I would suggest re-install Matlab, ISE and SysGen, there is a large possibility that software has some problems.
