Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
giorgos2
0
Problems with generating VHDL code
I am trying to generate VHDL code for my system-generator system, but i am facing problem below:
Summary of Errors:
Error 0001: caught standard exception
Block: Unspecified
Error 0001:
Reported by:
Unspecified
Details:
standard exception: XNetlistEngine:
An exception was raised:
com.xilinx.sysgen.netlist.NetlistInternal: time value is outside
permissable range
Unfortunately i can imagine what can cause this problem. Could anybody help me?
sidharthg
0
Re: Problems with generating VHDL code
Go into the sysgen folder in your project.
Check out the above mentioned file  "com.xilinx.sysgen.netlist.NetlistInternal" and search for time value.
Hope this helps.
Sid
Administrator
criley
0
Check out Xilinx's Master Answer Record for standard exception errors and see if any of the solutions resolve the problem:
http://www.xilinx.com/support/answers/29430.htm
You may also want to poke around your model and simply the FPGA clock period and Simulink System Period to find out if the "time value is outside permissible range" message is correct.   You can also set the "Block icon display" in the SysGen token to "Normalized sample periods" which is helpful in understanding where sample period change in the model.
