Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Trusted Contributor
mbssch
0
Accepted Solution
Reed Solomon Encoder outputs "NaN" in System Generator
Hallo community,
I built a SysGen model with the RS Encoder block involved. When I simulate the design, RS gives "NaN" (not a number) at all of its ouputs. Do I need a license for simulation in SysGen? I can't find any information about that.
Thank you
Stefan Schwarzer
nathanx
0
Re: Reed Solomon Encoder outputs "NaN" in System Generator
Ensure the input to RS Encoder are valid, try to use valid in and valid out for each block.
Trusted Contributor
mbssch
0
I think I did everything correct, but I still get the NANs. Could you please take a look at the model attached? I am using Xilinx 12.1 and Matlab 2010a. I know 2010a is beta for SysGen 12.1, maybe that is the problem!?
Stefan Schwarzer
Trusted Contributor
mbssch
0
Nope, same problem with 2009b.
So is it the license or did I do anything wrong in the model?
Trusted Contributor
mbssch
0
Well, I retrieved an evaluation license and now simulation works as expected. I don't blame Xilinx for that, it's normal business. But please, please, please write that down in the SysGen documentation somewhere!
xud
0
I remember it only occurs on RS v6.1 or v6.0. couldn't remember what's the exact version. Other cores should be fine.
