- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Sample rate issues with counter block?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-21-2011 08:43 AM
I am having trouble with the specifying the sampling rate of a counter block and receiving a different rate at the output during runtime. For example, say I set the Counter block sampling rate to 2.5e-8. When I manually (Format->Sample Time Display->All) go and have simulink calculate the sample time legend everything is perfect, but when I run the simulation I get 2.0972e-8. This really messes things up because the sample rate of the sysgen is set to 2.5e-8. Also, when I try to run the simulation I get an error stating the following:
The periodic sample time 1.0 is not allowed because the ratio of this sample time over base rate (3.199999999E-013) is greater than the maximum value of uint32.
I would pull the example into this forum, but I do not have access to transfer a screenshot or .mdl to this computer. Any help is greatly appreciated. If I am not being clear enough feel free to ask me questions. Thanks!
Using the following
Matlab 2010b
Sysgen 12.4
Windows 7
Solved! Go to Solution.
Re: Sample rate issues with counter block?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-23-2011 10:36 AM
It will help if you can attach your model. Something you may want to try is to change the solver to "Fixed-Step" "Discrete". (Under Simulation->Configuration Parameters menu).
travisdoll wrote:
Using the following
Matlab 2010b
Sysgen 12.4
Windows 7
Jim
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-25-2011 07:15 AM
Hi Jim,
Thanks for the response. The solver options are set to fixed-step as discrete (no continuous states) with fixed-step size to auto. I would attach the model if possible, but given my circumstances that is not allowed. Sorry. Here is a description of the problem area of my model:
Using all Xilinx blocks:
2 input Mux with inputs of a counter (1 bit) for select port and constants as inputs followed by a delay of 2 and a delay of 16
Counter FS is 2x
inputs FS are 1x
To simplify the situation, I reduced the sampling rates to the following:
Sel Counter FS = 1600Hz
Mux Inputs FS = 800Hz
When using the manual sample time legend population method I get the following sample rates for each block specified, which are the correct rates:
Sel Counter Output FS = 1600Hz
Mux Output FS 1600Hz
1st Delay Output FS = 1600Hz
2nd Delay Output FS = 1600Hz
During runtime the following samples rates occur for each block are specified below:
Sel Counter Output FS = 0.0016Hz
2nd Delay Output FS = 0.0016Hz
Thanks for any advice...sorry I can't post the model, but greatly appreciate the comments.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-25-2011 08:45 AM
Ok so I figured out my own issue. It has nothing to do with the counters, muxes, constants, etc. I am generating my subsystems dynamically for my overall system using add_block, add_line, and the such. In doing so I am not deleting the system generator each time and for some reason this has caused an issue. To solve my issue I deleted all non-top level system generator blocks and copied/pasted the top level system generator into each subsystem requiring the token. This seems to have taken care of the error. The sampling rates seem a bit weird from time to time, but everything runs as expected. Also, I changed the Block Icon Display in the system generator options verify the samling rates and all is ok there. It seems that the Sample Time Display does not exactly match the correct sampling rates of xilinx blocks during runtime. Hopefully this helps someone else out in the future. Thanks for the advice Jim, your comment got me thinking about things further.
Error 0001: Internal Error Block: 'DSP48CoPr ocessor/Pr ocessor Subsystem/ EDK Processor/ proc'
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-27-2011 07:10 PM
This message was moved by Xilinx Forum Moderator. If you have any questions, please contact Forum Moderator.
