- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
how to change the dsp_clk
[ Edited ]- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-25-2011 10:56 PM - edited 02-25-2011 11:16 PM
Helloeveryone,
I am using xilinx system generator. I generated my design for hardware co-simulation using that.
when i do that the clock that i am providing pass timing constraints without any problem for every path related to it,
but there is an internal clock called "dsp_clk" and timing related to those paths fail.
Can someone help me to acheive the timing in that path as well.
May be to decrease the clock(dsp_clk), currently it is 25ns. I am even not able to get a detailed report
of the failing paths in "dsp_clk" one either. I am using the gui to generate my design.
This is what i get.
* NET "dsp_clkibufg" PERIOD = 25 ns HIGH 50 | SETUP | -6.327ns| 31.327ns| 22| 136652 % | HOLD | -0.189ns| | 512| 65280
Thank you,
Best Regards,
Rana
Re: how to change the dsp_clk
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-30-2011 02:37 PM
You can't change this because this is the actual clock on the board.
You might want to try opening a case with the Xilinx Technical Support to see if they can help track this down.
You can also try increasing the pipelining of your design to see if that helps with meeting timing.
