- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
the problem when I generate a netlist file
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-09-2012 02:58 AM
why always ask this quetion when I generate a netlist file.
ERROR: A license checkout has failed for System Generator for DSP (SysGen).
------------------- A message from the license manager --------------
INFO:Security:56 - Part 'xc6slx45' is not a WebPack part.
INFO:Security:60 - The XILINXD_LICENSE_FILE environment variable is set to 'D:\Xilinx_ISE_DS_Win_13.1_O.40d.1.1\ISE_DS\common
INFO:Security:62 - The LM_LICENSE_FILE environment variable is set to 'D:\Xilinx_ISE_DS_Win_13.1_O.40d.1.1\ISE_DS\common
INFO:Security:68 - Please run the Xilinx License Configuration Manager
(xlcm or "Manage Xilinx Licenses")
to assist in obtaining a license.
ERROR:Security:9 - No 'SysGen' feature was available for part 'xc6slx45'.
ERROR:Security:12 - No 'xc6slx45' feature was available (-5).
No such feature exists.
Feature: SysGen
License path: C:/.Xilinx\Xilinx.lic;D:/Xilinx_ISE_DS_Win_13.1_O.
FLEXnet Licensing error:-5,357
Feature: xc6slx45
Reported by:
Unspecified
Re: the problem when I generate a netlist file
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-09-2012 01:30 PM
The clue is in the message itself.
The tool is unable to get the license file ?
Please check carefully the configuration for your license file ?
Is /.Xilinx containing a valid license file do exsist ?
Signature:
1.Have you ever tried typing your question into Google? If not you should before posting.
2.Read the datasheet and user guide. Have you read the user guide in detail ? Can you find the user guide?
3. Search the forums for similar topics.
4.I have neither found any similar thread in existing forum nor web-search is helpful to me.What should I do ?
Post your issue in detail comprehensive format on the relevant
forum.
5. Do not post the same question on multiple forums,please search and post it on relevant forum.
6. Do not raise a new topic or question on someone else's thread, start a new thread!
7. Students/Newbies: Copying code is not the same as learning to design.
8. "It does not work" is not a question which can be answered. Provide much details (with webaddress, datasheet links,etc..).
and make sure to be specific!
9. You are not charged extra fees for comments in your code,It will help others to understand well.
10.If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-09-2012 11:58 PM
hi,
pls have a look at the lic file in ur .xilinx folder of the instalation drive and kindly update ur ISe 13.2 to higher version i.e 13.2 to 13.4 as it happens to be with the same lic. Also see the link below for the compatibility
http://www.xilinx.com/support/answers/17966.htm
Chandrajit
