- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Cant Implement Top Modulu
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-07-2012 09:20 PM
I'm new to Xilinx.last week when I try to run my verilog programming,this happen:
WARNING:ProjectMgmt - File C:/Users/zarylL/testing1/testingcode1.stx is missing.
I try to create a new project.But the file still missing after I run for the first time.Could anyone kindly help me.
Re: Cant Implement Top Modulu
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-12-2012 11:54 PM
I have no clue yet what an .stx-file can be or what it is good for, but the screen just shows warnings, so still the design flow should be finished with something useful.
What kind of flow are you actually running and what makes you think that somethink isn't working?
Are there Errors too?
Actually, I just saw that I got this Warning too in my last implementation run. It happenad between XST and PAR.
But it was no harm at all. The design is running well on the board.
Always look at the Console outputs.
When you see something like this after starting "Generate Programming File":
Process "Generate Programming File" completed successfully
then you got a bitfile ready for configuring the FPGA.
If there are real problems, the flow will stop at the particular step and you can scrioll up the Console output to see the error messages.
Try again, and report back when you find some real problem with your design.
And then provide sufficient information for tracing the cause. (Tool version, Device type, Error Message etc.)
Have a nice synthesis
Eilert
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-07-2013 10:52 AM
I actually just encountered the same 'warning'.
Checking my syntax errored out with no error or warning messages.
Synthesizing my design does not complete successfully, but gives no error messages, only that warning mentioned in the original post. I find it strange that despite being a warning it does not synthesize.
After saying:
Started : "Synthesize - XST". Running xst... Command Line: xst -intstyle ise -ifn "<my_file_path_shortened>.xst" -ofn "<my_file_path_shortened>.syr"
It would just say synthesis failed. (The compiler flags may have changed, this was copied after the fact.)
I decided to restart ISE to see if it resolved itself. Upon relaunching ISE, windows bluescreened with a SYSTEM_SERVICE_EXCEPTION. (I'm running ISE 14.4 on Windows 7).
After my unintended reboot ISE initially gave me the same warning about a missing file, but after hitting synthesis it appears to have righted itself.
I can only assume that the original poster found something like this too, because a solution doesn't seem to have been posted in this thread.
Cheers,
dabell
