Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
kruljcina
0
Accepted Solution
CoreGen in ISE 13.1 not generating ndf file
Hi all,
I have been using ISE for long time and never
had any problems.
Couple of weeks ago I installed ISE 13.1
because my new board has Spartan6 FPGA and
some IP cores that are available with new CoreGen.
Since I also use 3rd party tools I need .ndf and .ngc files.
For some reason CoreGen that comes with ISE13.1 doesn't
generate ndf file. I tested it on two different computers with
same result. I tried with ISE12.1 and ISE12.2 on same computers
and their CoreGen produces .ndf files with no problem.
I can't see any differences between user interfaces in CoreGen.
I need 13.1 in order to generate new IP cores for Spartan6.
Is there something new that I am not seeing here?
I will appreciate any help on this mater.
  Best regards
Expert Contributor
gszakacs
0
Re: CoreGen in ISE 13.1 not generating ndf file
I'm not using 13.1 yet, but at least up through 12.x there is an executable in the
ISE\bin\nt directory called ngc2edif.exe, which should be able to convert the .ngc
file to .ndf format.
HTH,
Gabor
-- Gabor
kruljcina
0
Thank you Gabor !!!
This did the trick, I can now generate ndf files.
I still don't understand why coregen doesn't do
this anymore but with this workaround I am
back on schedule.
Thank you again for your help :-)
  Best regards
kruljcina
0
Just an update:
in ISE13.3 this issue hasn't been resolved yet.
viviany
0
What IP core are you using? And what 3rd parth tool are you using? Why do you need both .ndf and .ngc files?
Vivian
kruljcina
0
thank you for taking interest.
I am using Altium Designer for fpga development, and
it requires both ngc and ndf files in order for its IP
importer to work. Altium is just front end tool so
Xilinx tools are still used for design generation.
I have attached picture of ndf option in CoreGenerator,
when I enable this option in Ise11.x or Ise12.x I get
ngc and ndf file, but this option doesn't work since Ise 13.1
I tried with different cores (block memory, multiplier, TEMAC...)
but its always the same.
Only reason why I switched to ISE13.x is because I designed
board with Spartan6 for Ethernet application and I needed Temac
IP core.
Best regards
viviany
0
Thanks for your clarification. I'll follow up this.
Vivian
jcmajewski
0
Still an issue in 14.1!
