Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Super Contributor
garengllc
0
Generated core causing problems in par (ProjectMgmt warning)
I inherited a project that was started in 13.2, but I am currently running 13.4.  The project will Synthesize and everything fine, but as I look at the console,
I am getting a steady stream of: WARNING:ProjectMgmt - File Z:/blah/blah/blah/coregen/icon.vhd is missing
icon1 is a ICON core that was originally made when in 13.2.  Looking at the setting for it, it says that it is Verilog (which I want), so I don't know why it is looking for a .vhd file.  I tried regenerating the core, but that doesn't solve the problem.  I grepped for what is calling icon1.vhd, but couldn't find that in any of the project files.  When I start up chipscope, it claims to not see any cores, so I have a feeling it is related to this problem.
How to I clean this up so it doesn't keep choking on this?
Thank you!
viviany
0
Re: Generated core causing problems in par (ProjectMgmt warning)
Are you able to run the design through Synthesis, Implementation and Bitgen successfully? If so, this warning is not the cause of your chipscope issue.
I suggest you go to "Design Tools - Others" board, open a new post and describe your chipscope issue in detail (error message and etc.)
Vivian
