Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
bernhardfuchs
0
multiple boards inside 1 ISE Project
is it possible to configure an ISE 9.21 SP4 Project to handle the following constelation.
i´ve got 3 prototyping boards of the same  type and one different.
The design itself is the same including the pin-out. The difference is only a hardcoded "Node"-Address which defines interal behaviour.
The easiest way would be changing this address every time a board gets programmed. Because during Testphases its boring to wait until the design-flow is finished before its possible to programm the device.
Is there a way to tell ISE to create different BIT files for each Board and ( this would hit the spot) set different Pin Outs.
best regards
Bernhard
Expert Contributor
bassman59
0
Re: multiple boards inside 1 ISE Project
bernhardfuchs wrote:
best regards
Bernhard
You can do what you want if you run the tools using a script or batch file.
-a
Yes, I do this for a living.
