Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Contributor
orangepeace
0
There is something wrong with my PlanAhead when launch Modelsim
Hi All,
   My PlanAhead is 14.1 which can use ModelSim as simulator. But when I set ModelSim as simulator in PlanAhead, errors occurs. Pls help me.
Best Regards
Expert Contributor
sushantm
0
Re: There is something wrong with my PlanAhead when launch Modelsim
You should set the proper path for Modelsim exe file to use ModelSim for simulation environment.
--Sushant Mahajan
Signature:
1.Have you ever tried typing your question into Google? If not you should before posting.
2.Read the datasheet and user guide. Have you read the user guide in detail ? Can you find the user guide?
3. Search the forums for similar topics.
4.I have neither found any similar thread in existing forum nor web-search is helpful to me.What should I do ?
Post your issue in detail comprehensive format on the relevant
forum.
5. Do not post the same question on multiple forums,please search and post it on relevant forum.
6. Do not raise a new topic or question on someone else's thread, start a new thread!
7. Students/Newbies: Copying code is not the same as learning to design.
8. "It does not work" is not a question which can be answered. Provide much details (with webaddress, datasheet links,etc..).
and make sure to be specific!
9. You are not charged extra fees for comments in your code,It will help others to understand well.
10.If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
Regular Contributor
orangepeace
0
Hi sushantm,
   I have compiled Xilinx library by Simulation  library complication wizard and set environment variable MODELSIM. You mean I should set modelsim.exe path. How to set it?
Best Regards
Expert Contributor
sushantm
0
In ISE you should set
1.Go to Simulation Process properties
--> General Options
Property Names
1st option Target Simulator.
--> Set the desired simulator.
2nd option Language.
--> Set the desired language.
3rd option Simulator path
--> You should give the path for Model Sim exe here.
But I had really not tried with Plan Ahead 14.1 since it has realsed a week back.
Even for Plan Ahead 13.4 it supports ISIM as default simulator.
You can refer here
--Sushant Mahajan
Signature:
forum.
Expert Contributor
sushantm
0
Also verify that you had set the proper environment variable and the exe file exsist on that path.
--Sushant Mahajan
Signature:
forum.
Regular Contributor
orangepeace
0
   I tried it but it still doesn't work.
Best Regards
graces
0
This is a known issue in PlanAhead and dev team is working on it.
Current workaround is to launch Modelsim stand alone outside PlanAhead.
Expert Contributor
sushantm
0
Hey graces,
It seems that Plan Ahead 14.1 contains the option for Model Sim under project settings but we are unable to find the settings for integrated tools where we should set the path for modelsim.exe file.
--Sushant Mahajan
Signature:
forum.
graces
0
I think PlanAhead should by default find the executable in $PATH. If multiple modelsim paths exist, the first takes priority.
But your suggestion is a good one. The feature enables user to select the desirable modelsim version.
I'll file a enhancement CR.
BTW, the known issue will be fixed in 14.2.
