- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
not enough detail on planAhead 11.1 timing report
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-23-2009 03:22 PM
I am using planAhead to do post-layout timing analysis. When I import the timing report, violating path doesn't show everything.
timing report from planAhead showed one path went through few gates, but in ISE timing analyzer report, the same path went through way more gates than what planAhead was showing. I was trying the fix timing based on planAhead report, and effort went nowhere since I didn't know there were many more gates involved. Does anyone know why planAhead does this? Is there some kind of setting I need to do in planAhead to show all detailed path delay?
In planAhead 10.1, there was exploreAhead, so I can try the floorplan before running ISE. I don't see that feature anymore in 11.1. Anyone know what happened? Do we need to purchase exploreAhead separately?
Solved! Go to Solution.
Re: not enough detail on planAhead 11.1 timing report
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-26-2009 06:42 AM
onemanshow wrote:> I am using planAhead to do post-layout timing analysis. When I import the timing report, violating path doesn't show everything.
> timing report from planAhead showed one path went through few gates, but in ISE timing analyzer report, the same path went through way more gates than what planAhead was showing. I was trying the fix timing based on planAhead report, and effort went nowhere > since I didn't know there were many more gates involved. Does anyone know why planAhead does this? Is there some kind of setting I need to do in planAhead to show all detailed path delay?
[Jim] PlanAhead uses the instance/net names from the source netlists (edf and/or ngc). When you implement the design (i.e. run map/par), the backend tools may change/remove some nets/instances due to optimization. The timing report is based on the net/instance names in the final implementated design, which may or may not be the same as in the source netlists. When PlanAhead can't find a match between the source netlists and the timing report, you will see the inconsistency on PlanAhead GUI.
[Jim] It's called "Tools->Run Implementation..." now in 11.1
Cheers,
Jim
Jim
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-26-2009 05:42 PM
Hello Jim,
Thanks for the info.
So when timing report is imported to planAhead after PAR, it still doesn't know anything about implementation? I was expecting planAhead to import all implementation results, so I can trace routing of critical path. If planAhead can't do that, its not much of timing analysis tool.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-27-2009 01:23 PM
It does import all implementation result. Certain instances/nets names will be displayed differently if the names in the implentation result don't match the source netlist. Having said that, the transformation of instance/net names in backend tools (map/par) doesn't dramaticlly change the names, so PlanAhead will be able match the implementation result well with the netlist and can be very use for analyzing timing results.
Cheers,
Jim
Jim
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-27-2009 02:48 PM
Hello Jim,
You are right. Not all the names are the same, but its enough to identify the path. The bigger issue is that planAhead shows different level of logic in critical path. In ISE11.1, I open up one critical path and I see about 10 level of logic, but the same path in planAhead shows only 5. This is after implementation is imported to planAhead. I don't know if this is standard behavior.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-29-2009 10:13 AM
Without looking at the path in PA (planahead for short) and in the timing report, it's hard to say where this discrepancy come from. Would it be possible to post the path? What tool options did you use with map?
Cheers,
Jim
Jim
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-02-2009 04:20 PM
here is one example
timing report from ISE
Maximum Data Path: dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/dp_
Location Delay type Delay(ns) Physical Resource
SLICE_X52Y76.BQ Tcko 0.396 dp_rx_inst/DPP_RX_FIFO_INST/rd_ptr<3>
SLICE_X50Y78.C1 net (fanout=303) 1.189 dp_rx_inst/DPP_RX_FIFO_INST/rd_ptr<1>
SLICE_X50Y78.C Tilo 0.086 dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/dp_
SLICE_X53Y77.A2 net (fanout=1) 0.908 dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/lut
SLICE_X53Y77.A Tilo 0.086 dut_core_inst/R_EPCFG_ENABLE_bus_sync/in_d2<27>
SLICE_X55Y75.C4 net (fanout=11) 0.582 dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/lut
SLICE_X55Y75.C Tilo 0.086 dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/dp_
SLICE_X55Y80.D4 net (fanout=3) 0.648 dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/lut
SLICE_X55Y80.D Tilo 0.086 dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/N40
SLICE_X55Y80.C6 net (fanout=1) 0.119 dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/N40
SLICE_X55Y80.C Tilo 0.086 dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/N40
SLICE_X58Y83.C6 net (fanout=29) 0.497 dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/lut
SLICE_X58Y83.C Tilo 0.086 dut_core_inst/USB_ED2_WR_GRANT_REPLICA_1073
SLICE_X58Y83.D5 net (fanout=4) 0.239 dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/dp_
SLICE_X58Y83.D Tilo 0.086 dut_core_inst/USB_ED2_WR_GRANT_REPLICA_1073
SLICE_X56Y82.A5 net (fanout=22) 0.453 dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/DP_
SLICE_X56Y82.A Tilo 0.086 dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/lut
SLICE_X57Y80.D3 net (fanout=68) 0.686 dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/lut
SLICE_X57Y80.D Tilo 0.086 dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/dp_
SLICE_X78Y82.D4 net (fanout=2) 1.080 dut_core_inst/usb_inst/epc_ss_inst/EPC_RX_RAM_WR_B
SLICE_X78Y82.D Tilo 0.086 dut_core_inst/usb_inst/epc_ss_inst/epc_tx_inst/tp_
SLICE_X78Y82.C6 net (fanout=1) 0.133 dut_core_inst/usb_inst/USB_SS_RAM_WR_BE<2>
SLICE_X78Y82.C Tilo 0.086 dut_core_inst/usb_inst/epc_ss_inst/epc_tx_inst/tp_
SLICE_X58Y92.C2 net (fanout=12) 1.490 lut204363_28491
SLICE_X58Y92.C Tilo 0.086 dut_core_inst/ram_inst/lut1241_23885
SLICE_X64Y91.A5 net (fanout=47) 0.788 dut_core_inst/ram_inst/lut1242_23886
SLICE_X64Y91.A Tilo 0.086 dut_core_inst/R_EPCFG_STR_EN_U<17>
SLICE_X78Y83.D6 net (fanout=12) 0.770 dut_core_inst/RAMARB2_RD_OK
SLICE_X78Y83.D Tilo 0.086 dut_core_inst/usb_inst/epc_ss_inst/lmp_inst/LMP_RX
SLICE_X64Y75.B6 net (fanout=6) 0.805 dut_core_inst/usb_inst/epc_ss_inst/lut25454_7336
SLICE_X64Y75.B Tilo 0.086 dut_core_inst/usb_inst/epc_ss_inst/epc_rx_inst/tp_
SLICE_X61Y59.B6 net (fanout=1) 0.951 dut_core_inst/usb_inst/epc_ss_inst/RXH_EPC_ADV
SLICE_X61Y59.B Tilo 0.086 USB_DBG_OUT<40>
SLICE_X65Y55.C5 net (fanout=3) 0.598 dut_core_inst/usb_inst/RXH_ADV_epc
SLICE_X65Y55.C Tilo 0.086 dut_core_inst/usb_inst/epc_ss_inst/epc_tx_inst/dp_
SLICE_X64Y55.CE net (fanout=1) 0.248 ][134806_61987
SLICE_X64Y55.CLK Tceck 0.195 dut_core_inst/usb_inst/link_inst/link_tx_inst/lcrd
Total 14.237ns (2.053ns logic, 12.184ns route)
Timing report from planAhead
Maximum Data Path: pblock_epc_ss_inst/pblock_epc_rx_inst/epc_rx_inst/
Location Delay type Delay(ns) Logical Resource(s)
SLICE_X52Y76 FDCE (Tcko) 0.396 pblock_epc_ss_inst/pblock_epc_rx_inst/epc_rx_inst/
net (fanout=303) 1.189 pblock_epc_ss_inst/pblock_epc_rx_inst/epc_rx_inst/
SLICE_X58Y83 LUT6 (Tilo) 3.270 pblock_epc_ss_inst/pblock_epc_rx_inst/epc_rx_inst/
net (fanout=4) 0.239 pblock_epc_ss_inst/pblock_epc_rx_inst/epc_rx_inst/
SLICE_X58Y83 MUXF7 (Tilo) 0.086 pblock_epc_ss_inst/pblock_epc_rx_inst/epc_rx_inst/
net (fanout=22) 0.453 pblock_epc_ss_inst/pblock_epc_rx_inst/epc_rx_inst/
net (fanout=2) 1.938 EPC_RX_RAM_WR_BE[2]
LUT6 0.000 pblock_epc_ss_inst/RAM_WR_BE<2>1
net (fanout=1) 0.219 USB_SS_RAM_WR_BE[2]
net (fanout=12) 3.306 RAMARB2_RD_OK
logic (Tilo) 0.977 RXH_EPC_ADV
net (fanout=1) 0.951 RXH_EPC_ADV
LUT2 0.000 pblock_epc_ss_inst/RXH_ADV1
net (fanout=3) 0.684 RXH_ADV_epc
SLICE_X64Y55 FDCE (Tceck) 0.529 link_inst/link_tx_inst/lcrd_q_2
Total 14.237ns
planAhead report looks like a summary instead of detailed analysis. PlanAhead report is generated when I did ISE Tools --> PlanAhead --> Analyze Timing.
Also when I open planAhead through ISE, I don't see run implementation option anywhere. However if I open PlanAhead as stand alone, I see run Implementation option. Why is there feature difference?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-03-2009 07:37 AM
Looks like you turned on global optimization and retiming options in map as some of the signal names have the BRB suffix, which usually means map did register balancing on these paths. When that happes, these paths will be different (signal names as well as logic levels) from the original netlist.
I would first find out the critical paths in a design as it is written (i.e. no retiming or register balancing) and see if anything can be done in the source code to improve the timing.
Cheers,
Jim
Jim
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-03-2009 10:17 AM
Hello Jim,
We need to use global optimization to meet timing. If planAhead can't display all the optimization PAR did, then it is not useful as timing analysis tool. What I want to see is exact routing after PAR. What can I use to see this? With ISE 10.1, I can double click on a path and it will open up floorplanner and it shows exact routing. With ISE11.1, I don't see this feature.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-05-2009 10:42 AM
You need to keep your ultimate goal in mind: closing timing on your design. If the timing report shows that your critical paths are the ones optimized by the implementation tools, even if you had the best analysis tool, you can't do anything about them to achieve your goal (again closing timing). Those paths don't exist in your source code nor in your netlist, so you can't modify source code to address the issues nor can you constraint them in UCF. This is why I suggest you find out the real critical paths are in your design and handle them accordingly.
Cheers,
Jim
Jim
