Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
konghouwwx
0
A question about IBERT. Thank you.
Hi,all.
I use the IBERT CORE GENERATER(ISE13.2) to generate a IBERT core to test my rocketio,which connect with SFP(fibre channel).
However,the userguide(ug213) says,"
The GPIO (General Purpose I/O)options currently only include VIO core-controlled synchronous
output pins that can be used to control devices outside of the FPGA (such as SFP optical
modules)."
So I add GPIO connect to the SFP.But
ERROR:Pack:2811 - Directed packing was unable to obey the user design
constraints (LOC=F2) which requires the combination of the symbols listed
below to be packed into a single OPAD component.
The directed pack was not possible because: More than one pad symbol.
The symbols involved are:
BUF symbol "TXP0_OPAD_0_OBUF" (Output Signal = TXP0_OPAD<0>)
PAD symbol "TXP0_OPAD<0>" (Pad Signal = TXP0_OPAD<0>)
PAD symbol "VIO_OPAD<0>" (Pad Signal = VIO_OPAD<0>)
constraints (LOC=G1) which requires the combination of the symbols listed
below to be packed into a single IPAD component.
My question is ,should I add the GPIO?The step above this shows that the MGT has connected TX pins and RX pins.I'm
confused.What's the purpose of GPIO?
Thank you very much!God bless you.
mcgett
0
Re: A question about IBERT. Thank you.
The GPIO function is intended for controlling IO on the target board that may be necessary for enabling clocks, rests, etc.. It looks like you have assigned the GPIO in your design to the MGT pins hitch is not correct.
Have you tried typing your question into Google? If not you should before posting.
