- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
ILA clocking
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-13-2011 12:04 PM
What are the requirements for clocking the ILA? For example can I use a low frequency short pulse as a clock? (10kHz 8ns wide pulse)
Re: ILA clocking
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-13-2011 01:01 PM
http://www.xilinx.com/support/documentation/sw_man
One clocks all the logic, and the logic analyzer (Chipscope) from the same clock (generally).
Will everything meet timing and work with your proposed clock?
Principal Engineer
Xilinx San Jose
Re: ILA clocking
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-14-2011 04:22 AM
In this case the clock signal I want to use for the ILA is the data valid strobe which occurs after the data I want to observe is stable. I have a second ILA looking at the same data but using the system clock to drive the ILA clock. When I trigger the second ILA with the data valid strobe the data is always stable and correct. However when I use the Data valid strobe as a clock to the ILA the data reads back incorrect.
Re: ILA clocking
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-14-2011 04:24 AM
generate
if (DEBUG)
begin : chipscope
wire [255:0] TRIG0;
assign TRIG0[31:0] = MPMC_data_X;
assign TRIG0[63:32] = MPMC_data_Y;
assign TRIG0[64] = MPMC_strb;
assign TRIG0[65] = StartCalcLocal;
assign TRIG0[75:66] = MEM_addr;
assign TRIG0[107:76] = CalcData;
assign TRIG0[115:108] = state2;
assign TRIG0[116] = StartCalc_reg;
assign TRIG0[117] = calcDone;
assign TRIG0[149:118] = remoteData;
assign TRIG0[150] = StartCalcRemote;
assign TRIG0[255:151] = 0;
ila myIla (
.CONTROL(CONTROL0), // INOUT BUS [35:0]
.CLK(LocalTimeStampClock), // IN
.TRIG0(TRIG0) // IN BUS [99:0]
wire [255:0] TRIG3;
assign TRIG3[31:0] = MPMC_data_X;
assign TRIG3[63:32] = MPMC_data_Y;
assign TRIG3[64] = MPMC_strb;
assign TRIG3[65] = StartCalcLocal;
assign TRIG3[75:66] = MEM_addr;
assign TRIG3[107:76] = CalcData;
assign TRIG3[115:108] = state2;
assign TRIG3[116] = StartCalc_reg;
assign TRIG3[117] = calcDone;
assign TRIG3[149:118] = remoteData;
assign TRIG3[150] = StartCalcRemote;
assign TRIG3[255:151] = 0;
ila myIla2 (
.CONTROL(CONTROL3), // INOUT BUS [35:0]
.CLK(MPMC_strb), // IN
.TRIG0(TRIG3) // IN BUS [99:0]
end
endgenerate
Re: ILA clocking
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-14-2011 06:32 AM
Perhaps this is because it is not a clock.
It might work if you passed it through a BUFG/R.
Remember to add a KEEP attribute so that it survives synthesis.
"If it don't work in simulation, it won't work on the board."
