- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Regarding a signal being trimmed on chipscope pro
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-09-2012 11:21 PM
Hi All,
I have an 8 bit local signal which is used for some internal logic. Now the problem I am facing is when I am debugging using chipscope in the netlist signals , the 5th bit of the signal is trimmed and there is no warning or info regarding this.
I am sharing with you the pice of code related to this . I would be grateful if anyone of you could tell me any hint as to why this could happen. Earlier it was not giving any problem. It is a critical signal and I need to probe on it for my design so cant let go off it .
Here is the part of the code , THE SIGNAL IN QUESTION IS O_BYTE
PROCESS(CLOCK,RESET)
BEGIN
IF CLOCK'EVENT AND CLOCK = '1' THEN
IF RESET = '1' THEN
F_E <= '0' AFTER 1 NS;
F_D <= '0' AFTER 1 NS;
ELSIF ((B_SIZE = TRANS_LEN) OR (FLAG_S = '1')) THEN
ELSIF ((B_SIZE_2 = TRANS_LEN) OR (FLAG_S = '1')) THEN
ELSIF ((O_BYTE = X"0A") OR (O_BYTE = X"2A"))THEN
F_E <= '1' AFTER 1 NS;
ELSIF ((O_BYTE = X"28") OR (O_BYTE = X"08"))THEN
F_D <= '1' AFTER 1 NS;
END IF;
END IF;
END PROCESS;
please reply asap ..
akanksha
Re: Regarding a signal being trimmed on chipscope pro
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-17-2012 08:41 AM
BTW, if you are intending your RESET to be synchronous, it should not be in the process senstivity list.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-02-2012 06:30 AM
You also might uncheck "Trim Unconnected Signals" in MAP's properties
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-02-2012 11:48 PM
Hi Frnds
Well i put the keep attribute for teh signal i wished to probe on the chipscope. However , now I am getting this error. Could someone tell me about it , the reason and the solution for it. I do not wish to modify the exisying design by making any changes in the constyraints too as i want these signals for pure dubugging purpose.
Big block initial random placer cannot find solution. This is due to design being overconstrained by
user specified or clock region constraints. Try locking down the big blocks to improve this condition.
Please reply as soon as possible
akanksha
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-04-2012 08:49 AM
Can you setup a simple / nearly empty design and reproduce the error?
