- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
TIMESPEC TS_J_TO_D: user TIMEGRP 'D_CLK' must be previously defined in FROM/TO constraint
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-09-2010 04:05 PM
I am trying to use chipscope to test the memory controller using MIG for DDR2 for ML505. I have followed the steps (which are apparently not all correct) given on the below link.
http://www.xilinx.com/products/boards/ml505/ml505_
The chipscope (icon and ila) cores given with the reference design give the following error
ERROR:Xst:1617 - Processing TIMESPEC TS_J_TO_D: user TIMEGRP 'D_CLK' must be previously defined in FROM/TO constraint.
ERROR:Xst:1489 - Constraint annotation failed.
So I tried to generated new cores since the solution on this http://www.xilinx.com/support/answers/32425.htm mentions that the issue has been resolved in 11.1 version and I am using 11.4 version.
Can you tell me the constraints I might have to add in .ucf to get rid of this error??
Subject changed : Issue with Chipscope 11.4
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-11-2010 09:24 AM
Did anyone else working with Chipscope 11.4 had a similar issue?
Re: Subject changed : Issue with Chipscope 11.4
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-19-2010 07:47 AM
I have a similar, but not identical problem with the 11.4 tools and chipscope:
I am integrating an ICON core into my EDK project. I had it working fine, but I generated a new ILA core and now I can't get it to synthesize without that error.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-24-2011 02:51 AM
Don't want to create a new topic, so I'm posting my solution to the problem here.
Perhaps not related to this problem, but for those with this error message in non-EDK projects, this error is caused if the component declaration (in VHDL) mismatches the one specified in the .vho-file.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-17-2011 01:52 PM
I am getting the exact same errors --
ERROR:Xst:1396 - Processing TIMESPEC TS_J_CLK: No TNM or User group name J_CLK is defined.
using Chipscope 13.3. did you ever get a solution to this problem????
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-18-2011 10:09 AM
I found this to work:
Under Synthesis options, uncheck Read cores
Under Project options, cleanup project files(this deletes most of the generated files)
Compiles OK now
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-16-2011 11:07 AM
Update - It seems as if 13.3 has done away with the read cores check box option, so it has to be done as a command line option
on the Other XST Command Line Options add:
-read_cores no
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-10-2012 02:56 PM
Dear Kevin, I'm using EDK 13.3 GUI Windows, where do I have to add your " -read_cores NO" ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-12-2012 02:23 AM
I would also like to know where to add the " -read_cores NO"
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-31-2012 02:12 PM
It used to be a check box option, but Xilinx dropped that. You need to do it as a command line option
Under Synthesis >> process options ad the following command to "Other XST Command Line Options"
-read_cores no
