Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
argento
0
FFT 7.1 C Model gives blk_exp error when using C_HAS_BFP = 1
Hello Folks,
I'm running the C Modelexample provided with the package.
I'm using my data. I used Scheduled Scaling, but when I'm going to test Block Fixed-Point I get an error:
ERROR: blk_exp is incorrect: expected 14, actual 7
Some outputs from simulation are incorrect
Output of FFT is unusable, and very far from results I obtain with Scheduled Scaling.
Why is this happening?
How can I solve it?
ywu
0
Re: FFT 7.1 C Model gives blk_exp error when using C_HAS_BFP = 1
The blk_exp checking in the C model example is only valid for the input data used in the original example. If you use your own data, the blk_exp will be different, so you will need to remove the blk_exp checking in your C model.
The core automaically adjusts scaling in block floating mode, so blk_exp output can be different for each frame depending on the input data. You will need to left shift the FFT output by blk_exp to reconstruct the output data.
argento wrote:
Hello Folks,
How can I solve it?
Cheers,
Jim
argento
0
Ok, I'll remove that check.
But anyway, I'd be glad if you can teach me why blk_exp should be equal to nfft, if it is possible.
Thanks in advance
ywu
0
The blk_exp doesn't always equal to nfft. It happens to be nfft in the provided example when the input is a constant 0.5.
Thanks in advance
Cheers,
Jim
argento
0
Ok, I managed to use BFP.
One problem was I was using bad data.
Block Floating-Point seems to work now.
What is faster for the LogiCORETM IP Fast Fourier Transform v7.1,
to use a Scaling Schedule or BPF ?
ywu
0
If by "faster" you mean Fmax, the difference between scaled and block floating point is negligible. You can easily generate two netlists and compare the Fmax yourself.
Cheers,
Jim
