- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Video Scaler - Intc_if signals
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-23-2012 01:52 AM
I'm currently working with the video scaler IP v6.00.a and I have a problem when generating the core with the GUI interface:
After checking the check box "Include INTC Interface" and generating the core, I don't see any signals corresponding to the INTC_IF interface in the HDL Instantiation Template.
I checked the *.xco file, and the line "CSET has_intc_if=true" seems to be set correctly.
I also tried to instantiate the core with the intc_if signals (even if the instantiate model doesn't include this signals), but I get errors during the synthesis process.
Please tell me how i can access INTC_IF signals in my design.
I'm using the 14.1 version of ISE.
Thank you,
Julien
Re: Video Scaler - Intc_if signals
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-23-2012 06:21 AM
Can you provide your .xco so we can test it out?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-23-2012 07:47 AM
Here it is:
# Xilinx Core Generator version 14.1
# Date: Wed May 23 08:12:36 2012
# This file contains the customisation parameters for a
# Xilinx CORE Generator IP GUI. It is strongly recommended
# that you do not manually alter this file as it may cause
# unexpected and unsupported behavior.
# Generated from component: xilinx.com:ip:v_scaler:6.00.a
# BEGIN Project Options
SET addpads = false
SET asysymbol = true
SET busformat = BusFormatAngleBracketNotRipped
SET createndf = false
SET designentry = VHDL
SET device = xc6vlx75t
SET devicefamily = virtex6
SET flowvendor = Other
SET formalverification = false
SET foundationsym = false
SET implementationfiletype = Ngc
SET package = ff784
SET removerpms = false
SET simulationfiles = Structural
SET speedgrade = -1
SET verilogsim = false
SET vhdlsim = true
# END Project Options
# BEGIN Select
SELECT Video_Scaler xilinx.com:ip:v_scaler:6.00.a
# END Select
# BEGIN Parameters
CSET aperture_end_line=719
CSET aperture_end_pixel=1279
CSET aperture_start_line=0
CSET aperture_start_pixel=0
CSET auto_hsf=true
CSET auto_vsf=true
CSET chroma_format=4:2:2
CSET coefficient_file=C:\Local\583\DCV6\src\scaler\coe\
CSET component_name=Scaler
CSET has_axi4_lite=true
CSET init_coef_source=COE_File
CSET manual_hsf=1048576
CSET manual_vsf=1048576
CSET maximum_number_of_active_lines_per_input_frame=204
CSET maximum_number_of_active_lines_per_output_frame=10
CSET maximum_number_of_active_pixels_per_input_line=204
CSET maximum_number_of_active_pixels_per_output_line=19
CSET maximum_number_of_coefficient_sets=1
CSET maximum_number_of_phases=4
CSET number_of_horizontal_phases=4
CSET number_of_horizontal_taps=12
CSET number_of_vertical_phases=4
CSET number_of_vertical_taps=12
CSET output_horizontal_size=1280
CSET output_vertical_size=720
CSET separate_hv_coefs=false
CSET separate_yc_coefs=false
CSET source_horizontal_size=1280
CSET source_vertical_size=720
CSET target_core_clk_freq_mhz=200
CSET target_max_frame_rate=60
CSET video_data_width=10
CSET yc_filter_config=2
# END Parameters
# BEGIN Extra information
MISC pkg_timestamp=2012-03-11T15:50:56Z
# END Extra information
GENERATE
# CRC: 1cc178a1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-24-2012 06:52 AM
Any information ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-30-2012 05:49 AM
Dear bwiec,
Do you have any news regarding my issue ?
Thank you,
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-18-2012 02:48 AM
Any workaround please ?
