Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
m.eragh
0
Weird problem with DDS Compiler 4!
I am using a DDS compiler core in my Project. When I change the option of Keep Hierachy to "No", my design works properly and I get the right DDS Data.
When I change the option to "Yes" , everything is ok in the design except that I get the wrong DDS datas. but surprisingly the Datas are not wrong inherently, every single data is correct but the order of datas has changed. BTW, in this case I get this warning : DDS_tester_ins/DDS_ins/BU2/U0/I_SinCos.i/i_rtl.i_quarter_table.i_addr_reg_c/Mshreg_opt_has_pip.pip is incomplete, the signal does not drive any load pins in the design.
Could it be the problem? I guess in this case the DDS core is not reading the data from right addresses in its LUT!!!!!!
bwiec
0
Re: Weird problem with DDS Compiler 4!
Is this hardware or sim?
You will probably need to post your .xco and synthesis reports. Perhaps your instantiation code as well.
Do you have any chipscope/sim plots showing the behavior that you can share?
www.xilinx.com
m.eragh
0
Actually it is the hardware. I have simulated my DDS_Tester module ( instantiation module) and it is working properly. I cannot simulate the whole design simultaneously, since there are some PC interfaces in my design that cannot be simulated.
Anyway, after several tests I came to the point that any change in the deign that removes that warning will lead to the right DDS data. for example I changed the latency of the DDS core and it removed the warning ( I reduced the latency and this is quite awkward that reducing the latency has solved the problem!!!)
 This problem is quite weird since every single data is correct and they follow a logical order!!!!! for example in some of part of the period if we negate that part, it will make a complete Sine Wave but with some samples lost! . As I said before, I guess the DDS core is not reading data from the correct LUT addresses. I cannot post the xco and chipscope waveforms since the project is secured and I don't have permission to move the data :( .
bwiec
0
I would investigate if your design is meeting timing.
What kind of rates are you running at?
www.xilinx.com
m.eragh
0
The timing constraint is not met since I am working with the clock frequencies 24 and 100 Mhz. but the there's only one register between the clock domains( which is just a flag in order to tell the DDS module to start the process). My DDS module is working at 100 Mhz and there's a USB controller module which works at 24 Mhz.The USB controller has a register control to tell the DDS module to start the process.
But in both cases, ( right and wrong DDS data ) the timing constraint is not met . Could it be the problem? Notice that the only clock crossing area is the start flag register.
Another point : I decided to Use two DDS modules : one for phase generating and one for sine data generating in order to see whether phase data order is correct or not. I once used a chipsope core and the DDS datas were correct!!!!!! ( in this case i didnt get that warning).
when I removed the chipscope core, again I got that warning and the wrong data!!
Regular Contributor
juergenatduerr
0
I am not sure, but can it be the case, that chip socpe registes the data in a correcter/better qay, than you do?
From you description you seem to have a cross domain clocking issue between DDS synthesis and physical observation at USB. (?)
Have you tried to implement an own DDS? Personally I do not use the XI DDS anymore after having compare their output with mine. See the diagram here http://www.mikrocontroller.net/topic/251921#2593000
