Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Expert Contributor
golson
0
Accepted Solution
Connect to different MB processors using xmd
  I have a design with two Microblaze Processors.  And have created two seperate Memory tests for each separate
processor system.  Now I want to run these tests.  I used the command in xmd console
connect mb mdm
This command will connect to mb number 0 by default.  How do I change this command to connect to
mb number 1.
johnmcd
Re: Connect to different MB processors using xmd
Look at xmd in UG111. Specifically look for 'cpunr'.
Expert Contributor
golson
0
Thank You for the information.
I used the following commands:
connect mb mdm -debugdevice cpunr 1
connect mb mdm -debugdevice cpunr 2
and accessed the following documents for info / examples.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_4/est_rm.pdf
http://xilinx.wikidot.com/u-boot
Regular Contributor
system85
Hello
the simple way i find to run two processor i open two xmd console.
when yopu open the xmd console you must choose your processor , than for the first time you choose processor 0 and than for the second time you choose processor 1
In each xmd console you point to the folder of the correspondant executable file
 in the processor 1 you must type
connect mdm -uart and then   terminal -jtag_uart_server 4321
you open an hyperteminal console , you connect to mdm uart of the second procesor with telnet and port 4321
Than you download your elf for each processor and type run for each one
Expert Contributor
golson
0
Hi system85,
  Thank you for the additional information.  I will give this a try.
Gary
