Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
zhbeagle
0
ML505 V5LX110T
I have a  ML505 V5LX110T board ,but I have encountered problems when using the reference designs here
http://www.xilinx.com/products/boards/ml505/ml505_92i/reference_designs.htm,I know it's because the diferent pin of V5LX110Tand V5LX50T.
Could somebody give me a solution?
best regards
barriet
0
Re: ML505 V5LX110T
You don't detail what specific issues you are having, but if the design uses transceivers (GTP) - they will need to be adjusted:
http://forums.xilinx.com/t5/Virtex-Family-FPGAs/How-to-assign-the-bankless-pins/m-p/227013
If the design uses other die-based coordinates (e.g. IDELAYCTRL) - I could imagine similar issues.
The regular SelectIO should be fine, which is why I assume it is the transceivers since you reference the pin-out.
bt
austin
0
Re: ML505 V5LX110T
z,
You have a XUPV5 pcb, NOT! a ML505.  They are similar, but they have different schematics, and different design libraries.
Go find the XUPV5 documentation, and use that, NOT the ML505.
http://www.xilinx.com/univ/xupv5-lx110t-refdes.htm
Austin Lesea
Principal Engineer
Xilinx San Jose
