Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
vij.ema
0
Accepted Solution
NPI-MPMC EDk 13.1
Hi all,
I am using EdK 13.1, SP 601, I have developed NPI interface for MPMC. It is a 32 bit NPI, trying to write to DDR2. I have obsereved the NPI signals in chiscope, seems to be ok, but I could not find the values in DDR2, I am reading DDR2 from MicroBlaze-PLB slave. Using XMD, I am able to write to DDR2 and read from DDR2. But through NPI, I could not write.
I am trying to write to address zero.  NPI clock and MPMC_clk0 are same and running at 100MHz. MPMC_2x clock is 300Mhz.
I have attached the chipscope analyzer waveforms . any solutions/comments are appreciated..thanks in advance..
How to add these  NPI/VFBC  bus signals to chipscope, everytime, I am genrating a new set of outputs for chipscope, seperately and connecting to ILA. somehow, I couldn't add VFBC or NPI buses XIL_NPI  to chipscope?..
If the MPMC base address is 0x10 00 00 00 , and if I want write to the first location of memory, then I shoudl send 0x0 on NPI address bus, am I right?.
vij.ema
0
Re: NPI-MPMC EDk 13.1
..and here is the complete MHS file.
Expert Contributor
gszakacs
0
I could be wrong, but I thought that the address to the NPI port needs to match the
address map of the microblaze, so the memory base address would come from:
PARAMETER C_MPMC_BASEADDR = 0x10000000
At least that is how it worked in older versions of the MPMC.  There may also be settings
for the port addressing when you customize and generate the MPMC.
-- Gabor
-- Gabor
vij.ema
0
Thanks for the quick reply Gabor, but I tried both, 0x0 address and MPM Base address, nothing is written to DDR2.
transactions on WR_FIFO EMPTY signal shows that, data is written to FIFO and tramitted out, but I read some junk data from those locations..thorugh PLB
Expert Contributor
gszakacs
0
My other (after) thought was that you're having a cache issue.  Are you invalidating cache
before reading the RAM?  Have you tried turning off cache?
-- Gabor
-- Gabor
jrobertson@motionanalysis.com
Gabor is right, the address should be the address in your MHS (0x10000000)
assign byte enable all high '1
assign RdModWr = Addr_Req
is your chipscope triggering on ~4x ISIP_Clk?
make sure to wati for Addr_Ack before de-asserting Addr_Req
check your npi pcore too
vij.ema
0
Thank for the reply, problem is with Byte Enable, I send 0x0 instead of 0xF, so no byte weill be written..
