Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
0
Accepted Solution
SDK : error 1260 - Process_begin: CreateProcess (C:Windows\temp\make5544.bat) failed
Hi all,
I'm facing a problem with SDK : I launched it today, tried to rebuild my project (it was working perfectly yesterday) and I got this error message :
Console Tab :
make all
process_begin: CreateProcess(C:\Windows\Temp\make5444-1.bat, C:\Windows\Temp\make5444-1.bat, ...) failed.
make (e=1260): Error 1260
make: *** [src/AutoTest.o] Erreur 1260
Problems Tab :
Description                                                         Resource             Path                 Location                Type
make: *** [microblaze_0/lib/libxil.a] Erreur 2        Modern_bsp                                                              C/C++ Problem
make: *** [src/AutoTest.o] Erreur 1260                Modern        C/C++ Problem
make[1]: *** [profile_includes] Erreur 1260          Modern_bsp                                                              C/C++ Problem
Obviously, I tried to clean the project, rebuild it again and again, restart SDK and my computer without any success.
I also tried to build the same project on another computer with success, so the problem isn't the code.
I haven't found any information about this issue on the Internet.
Thank you in advance for your help !
mat
0
Re: SDK : error 1260 - Process_begin: CreateProcess (C:Windows\temp\make5544.bat) failed
Note : I can't even compile a simple "Hello World" sample project
0
[ Edited ]
Ok, I think I found the cause of this problem : it's the new software policy restriction of my company that doesn't allow me to launch a .bat from C:\windows\temp
0
Same issue.
Do you know how to change the path used by Xilinx tools to create processes ? (In your case, C:Windows\temp)
0
Regular Contributor
0
Did you find a work around for this because it is happening to me?
