- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
SP605 vs. ML501 bitstream download
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-06-2010 11:49 PM
Hi there,
I used a Virtex 5 board (ML501) up to now, and to download a bitstream on it, it was enough to click the edk button "download bitstream".
Now with the Spartan6 SP605, the only way which works is to connect by XMD, then use the "dow" command and the bitstream ".elf", then the "con" command.
Why?
I don't see why I should use the debugger anytime I want to download a bitstream...
I looked for all the documentation, but there are mainly documents on how to use the designs which are already loaded with the kit, rather then help the user to implement his own.
Michele
Solved! Go to Solution.
Re: SP605 vs. ML501 bitstream download
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-07-2010 06:40 AM
Hi, found out why:
I have in this case a larger application software, which has to be loaded to DDR3, and this happens with the MDM core, through JTAG and XMD, but has nothing to do with the bitstream. Before, my application happened to stay in the internal block RAM, so the code was embedded in the bistream.
Michele
