Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Super Contributor
shantanu75
0
Re: Very Difficult , Need Aid:- FPGA Not Sending Out Data (UART Problem)U f
Congrats! So you finally made your FPGA to communicate with the Modem.
All LED ON means you want to press the PB to repeat.
Now try to understand the code which I have sent you and try to modify according to your requirement.
Already in the code I am saving the received data in an array - So you can check it - You can check in  particular position what data ou are getting.
Shantanu
Shantanu Sarkar
http://www.linkedin.com/pub/shantanu-sarkar/0/33a/335
Super Contributor
moraali
0
Good evening,
    Thank you for replying. So sorry disturbing you . I know you are busy. But i really need your help. I spent this few days understanding your coding. but there are some questions that i want to ask you ;-
1)
    RED  = Do not understand the function
    BLUE = The question regarding the RED
a) Please explain in detail of the RED purpose .
b) I having problem understanding the calculation LCD-hexadecimal relationship. Can you explain to me in detail. OR do you have any articles or references for that? I would like to read. I read in the internet , but I got confuse.
// Located in: microblaze_0/include/xparameters.h
#include "xparameters.h"
#include "uartlite_header.h"
#include "xbasic_types.h"
#include "xgpio.h"
#include "gpio_header.h"
/************************** Constant Definitions ****************************/
//The following constant is used to for Delay Counter
#define DELAY_CONSTANT     10000
 * The following constant controls the length of the buffers to be sent
 * and received with the UART, this constant must be 16 bytes or less since
 * this is a single threaded non-interrupt driven example such that the
 * entire buffer will fit into the transmit and receive FIFOs of the UART
#define TEST_BUFFER_SIZE      16
#define GLOBAL_BUFFER_SIZE 32 //Max limit of Global_RX_Buffer
#define No_OF_COMMANDS       4   //hERE i'VE DEFINED 4 COMMANDS
/************************** Function Prototypes ****************************/
void Func_Delay(int Loop_counter);
void Send_Byte_to_LCD(Xuint32 LCDBit);
void Send_PKT_to_LCD(char *LCD_Byte,Xuint8 LineNo);
//Function To Clear the display to LCD
void Clear_LCD(void);
//Display Failure Message in LCD
void Disp_Failure_Msg(void);
//Reset Global RX Buffer and its End Pointer
void Reset_Global_Buffer(void);
//Send Commands to Modem thru DCE Rs232 Port
XStatus  Send_Command_To_Modem(unsigned char * Command_Text);
//Get Response of the Command set
void Get_Response_of_Command(Void);
//Function To SEND cARRIAGE rETURN & LINE fEED TO RS232 PORT
XStatus Send_End_of_Text_to_RS232(Xuint16 DeviceId);
//Function To wait for Push Button to be pressed
Xuint32 Wait_for_PB(void);
//Global Variables
extern Xuint8 Global_RX_Buffer[GLOBAL_BUFFER_SIZE]; /* Global Buffer for Receiving Data */
extern unsigned int Global_RX_Buf_EndPTR; /* Global Pointer pointind end of the Global Buffer for Receiving Data */
int main (void)
   Xuint32 LCDBit;
   Xuint32 LedBit;
   Xuint32 Temp32Bit;
   Xuint32 Dip_SW_Val;
   //Set the Flag when the serial communication gets syncronized between FPGA & Modem
   Xuint32 Flag_Syncronize = 0;  Why do we to create Flag? What is the function?
   XStatus status;
   int Index;
   //Enable and initialize cache
   #if XPAR_MICROBLAZE_0_USE_ICACHE
      microblaze_init_icache_range(0, XPAR_MICROBLAZE_0_CACHE_BYTE_SIZE);
      microblaze_enable_icache();
   #endif
   #if XPAR_MICROBLAZE_0_USE_DCACHE
      microblaze_init_dcache_range(0, XPAR_MICROBLAZE_0_DCACHE_BYTE_SIZE);
      microblaze_enable_dcache();
   #endif
 //Initialise LCD
   //XStatus status;
   Func_Delay(1);//Initial PWR On Delay > 15mSec
   // Set for 4-bit LCD mode
   LCDBit=0x03; why is it 0x03? What does it do?
   Send_Byte_to_LCD(LCDBit);
   Func_Delay(1); //>4.1mSec
   LCDBit=0x03; Why it appear another time? What the purpose doing it again ?
   Func_Delay(1);//>100uSec
   LCDBit=0x03; What the purpose doing it again ?
   LCDBit=0x02; //4 Bit /  why is it 0x02? What does it do?
   //2 Lines / 5X7
   LCDBit=0x02; //4 Bit /  Why it appear another time? What the purpose doing it again ?
   LCDBit=0x08;
   Clear_LCD();
   //Initialization ends here
   Send_PKT_to_LCD("Testing LCD",1);
   Send_PKT_to_LCD("Press any PB",2);
 status = Out_GPIO(XPAR_LEDS_DEVICE_ID, 0xFF); Just want to ensure that this will light up all the LEDs . But we need to put it in status?
 Temp32Bit =Wait_for_PB();
 status = Out_GPIO(XPAR_LEDS_DEVICE_ID, 0x00); Just want to ensure that this will not light up any the LEDs . But we need to put it in status?
 do//Clear the RX Buffer as a initialization
 {  Func_Delay(5);
    Temp32Bit = UartLite_Receive_Data(XPAR_RS232_DCE_DEVICE_ID);
 }while(Temp32Bit > 0);
 //For syncronization Send "AT\r" to Modem and check for "AT" in the Received byte
 //Repeat untill "AT" is not received.
 Clear_LCD();
 Flag_Syncronize = 0; //Reset the Flag
 Send_PKT_to_LCD("Synchronizing...",1);
 do
  Func_Delay(200);
  if((++LedBit)>= 0xFF)LedBit=0x00; why do we need to do this? What is the purpose?
  status = Out_GPIO(XPAR_LEDS_DEVICE_ID, LedBit);
  Reset_Global_Buffer();
  Send_PKT_to_LCD("                ",2); Why is it blank? What is the purpose making it empty?
  status = Send_Command_To_Modem("AT");
  if (status != XST_SUCCESS)
  Disp_Failure_Msg(); //Display Failure Message in LCD
  status = Send_End_of_Text_to_RS232(XPAR_RS232_DCE_DEVICE_ID);
  Get_Response_of_Command();
  for(Index=0; Index < Global_RX_Buf_EndPTR; Index++) What actually this for loop does? Why the Flag_Syncronize should be 1?
     if((Global_RX_Buffer[Index] == 'A') && (Global_RX_Buffer[Index+1] == 'T'))
         Flag_Syncronize = 1;
  if(Flag_Syncronize > 0)break;
 }while(1);
 //Now ready to communicate.....
 Clear_LCD();
 Send_PKT_to_LCD(&Global_RX_Buffer[0],2); what does it display? Why it is 0 index in "&Global_RX_Buffer[0]" ?
 Send_PKT_to_LCD("Ready",1);
 for(Index=0,LedBit=0x01; Index < 8; Index++)
  Send_PKT_to_LCD(".",0);
  Func_Delay(200);
  LedBit=LedBit << 1;
 status = Out_GPIO(XPAR_LEDS_DEVICE_ID,0x00);
 Clear_LCD();
 while(1)
  if((++LedBit)>= 0xFF) What does it means? Why it has ++LedBit? what is the function of ++LedBit?
     ledBit=0x00;
  status = Input_Gpio(XPAR_DIP_SW_DEVICE_ID, &Dip_SW_Val); what is the function of doing this ?
   break;
  switch(Dip_SW_Val)
   case 0x01:
   Send_PKT_to_LCD("AT+CMGF=1",1);
   status = Send_Command_To_Modem("AT+CMGF=1");
   break;
   case 0x02:
   Send_PKT_to_LCD("AT+CMGS=+60179310740",1);
   //Breaking the Command as one cannot send more than 16 bytes at a time.
   status = Send_Command_To_Modem("AT+CMGS=");
   if (status != XST_SUCCESS)break;
   status = Send_Command_To_Modem("+60179310740");
   break;
   default:
   Send_PKT_to_LCD("AT",1);
   break;
   break;
  Temp32Bit =Wait_for_PB(); What is the reason of putting it in 'Temp32Bit" ?
  Clear_LCD();
    * Disable cache and reinitialize it so that other
    * applications can be run with no problems
      microblaze_disable_dcache();
   #endif
      microblaze_disable_icache();
   #endif
   return 0;
//Function required for Time Delay
 volatile  int i;
 volatile  int j;
 for(i=0; i<= Loop_counter; i++)
  for(j=0; j<=DELAY_CONSTANT; j++);
//Function To send Byte to LCD
 XStatus status;
 status = Initialise_LCD(XPAR_LCD_4BIT_DEVICE_ID);//Initialize the GPIO used for LCD
 status = Out_LCD(XPAR_LCD_4BIT_DEVICE_ID, LCDBit);  what is the purpose of the "status"?
 Func_Delay(0);
 //Toggle Enable Bit
 status = Out_LCD(XPAR_LCD_4BIT_DEVICE_ID, (LCDBit | 0x40) ); Why is it OR? And why is it 0x40? how do you calculate?
 Func_Delay(0);
 status = Out_LCD(XPAR_LCD_4BIT_DEVICE_ID, (LCDBit & 0x3F) ); Why is it AND? And why is it 0x3F? how do you calculate?
 Func_Delay(0);
//Function To send Packet to LCD
void Send_PKT_to_LCD(char *LCD_Byte, Xuint8 LineNo)
 static Xuint8 No_of_Char;
 Xuint32 LCDBit;
 Xuint8 LCD_Byte_Ptr;
 if ((LineNo & 0x03) > 0)//New Line 0x03 denote what ?
   if (LineNo == 2) 2 denote what?
   {LCDBit=0x0C;} //Set Addr to 2nd Line 0x0C denote what?
   else
   {LCDBit=0x08; }//If Bit 1 is High (1 or 3) - Set Addr to 1st Line 0x08 denote what?
  No_of_Char = 0; why  it should be 0?
  Send_Byte_to_LCD(0x00); what is 0x00 means?
 No_of_Char = 0; why need to do it again? what is the purpose?
 //If 0 then continuation to the previous
 //ie same line as previous
 for(LCD_Byte_Ptr=0; ;LCD_Byte_Ptr++) what actually this for loop does ?
    if(LCD_Byte[LCD_Byte_Ptr]<=0)
      break;
   LCDBit = 0x20 | ((LCD_Byte[LCD_Byte_Ptr]>>4) & 0x0F); what purpose of this ? Whay is it 0x20?
   LCDBit =0x20 | (LCD_Byte[LCD_Byte_Ptr] & 0x0F);
  if(++No_of_Char > 16)
    LCDBit=0x08; //Set Addr to 1st Line
    Send_Byte_to_LCD(0x00); why it should be 0x00?
    No_of_Char = 0;
    break;
 Xuint32 LCDBit;
 LCDBit=0x00;//
 Func_Delay(0);
 LCDBit=0x08; //Display Off why is it 0x08? What the function of this ?
 Func_Delay(0);
 LCDBit=0x00;//4 Bit  why is it 0x00? What the function of this ?
 Func_Delay(0);
 LCDBit=0x01; //Clear Display why is it 0x01?
 Func_Delay(0);
 Func_Delay(0);
 LCDBit=0x06; //Entry Mode - Incremental / No Shift why is it 0x06? What the function of this ? What increment ?
 Func_Delay(0);
 Func_Delay(0);
 LCDBit=0x0E; //Display On - Cursor On / No Blinking why is it 0x0E? What the actually it does ?
 Func_Delay(0);
 XStatus status;
 unsigned int ReceivedCount;
 //Clear RX Buffer before sending Data
 ReceivedCount = UartLite_Receive_Data(XPAR_RS232_DCE_DEVICE_ID);
 Func_Delay(10);
 status = UartLite_Send_Data(XPAR_RS232_DCE_DEVICE_ID, & Command_Text[0]);
   if (status != XST_SUCCESS) return XST_FAILURE;
 else return status;
 do//Wait till there is no data
 {  Func_Delay(5);
 }while(ReceivedCount <= 0); What the actually it does ?
 do//Keep on receiving till buffer is not empty
 {  Func_Delay(5);
 }while(ReceivedCount > 0); What the actually it does ?
 Send_PKT_to_LCD(&Global_RX_Buffer[0],2); What the actually it does ? Why is the GLOBAL_RX_Buffer index is 0?
 XStatus status;
 char  End_of_Text[3];
 End_of_Text[0]= 0x0D; why is it 0x0D?
 End_of_Text[1]= 0x0A; why is it 0x0A ?
 End_of_Text[2]= 0x00
why is it 0x00 ?
 status = UartLite_Send_Data(DeviceId, &End_of_Text[0]);
   return status;
 XStatus status;
 Xuint32 PB_Value = 0;
 do
  status = Input_Gpio(XPAR_PB_SWS_DEVICE_ID, &PB_Value);
 }while((PB_Value <= 0)||(status == XST_FAILURE));
 return PB_Value;
 Xuint32 PB_SW_Val;
 XStatus status;
 Clear_LCD();
 Send_PKT_to_LCD("FAILURE",1);
 Send_PKT_to_LCD("Press PB Switch",2);
 PB_SW_Val = Wait_for_PB();
 unsigned int Index;
 for(Index=0;Index<GLOBAL_BUFFER_SIZE;Index++)
 Global_RX_Buffer[Index]= 0x00; why is it 0x00? What does it do ?
 Global_RX_Buf_EndPTR = 0; Why 0? Is it the end pointer?
2)
a)
      Based on the below diagram, where is function part (above coding, please highlight for me in GREEN) for receiving the data from the Modem? I still do not understand how you did it ? How can the coding differentiate OK or ERROR
I am sorry if my questions is silly. But I really want to understand your wonderful coding throughly, so that i will be confident during my presentation.
Please reply to me as soon as possible.
Thank you very much . I really do appreciate your kind help.
Super Contributor
moraali
0
Good morning ,
   Are you there? I really need your help.
Thank you
Super Contributor
shantanu75
0
Regarding LCD pl find the attachment. Pl go thru it.
Shantanu
Shantanu Sarkar
Super Contributor
moraali
0
Good evening
  I am sorry to disturb you. But I need your help. I am trying for the past few weeks but I can rectify this problem
AT  //I type at the hyperterminal
OK // respond by the modem
AT+CMGF=1
OK
AT+CMGR=6 // read SMS at the index 6
+CMGR: "REC READ","+60166223610",,"09/03/10,18:02:35+32"
1  // This is the only input that need to extracted.
OK
I altered the code but the answered I getting are not static . It always changing
1) Sometimes it appears like this at the LCD
1|| ||| OK
2) When I rerun again, it often it appears like this at the LCD
2" || ||| 1 || ||| OK
or
32" || ||| 1 || ||| OK
or etc
The code is in the attachment. How can I rectify this problem to get a static answer.
Super Contributor
moraali
0
Good evening,
   Above mail ,I just added this code in the program.
  void Get_MResponse_of_Command(Void) // I change the name
       char s ; //I added this
       {  Func_Delay(5);
      {  Func_Delay(5);
       //ADDED HERE
      Send_PKT_to_LCD(&Global_RX_Buffer[25],2); // it will appear  1 || ||| OK
      Global_RX_Buffer[26]= 0x00;
// Delete the remaining after the 1 . Eg:- This  1 || ||| OK  will appear  1
      //UartLite_Send_Data(XPAR_RS232_DCE_DEVICE_ID, &Global_RX_Buffer[25]);    // Send 1 to hyperterminal so that I can see
       char *z = &Global_RX_Buffer[25]; // Change it to char type
       if(*z == '1')
           Out_GPIO(XPAR_LEDS_DEVICE_ID, 0xFF);  //light up LED
 The only problem I facing is that the input extracted is not always the same . How can I get an accurate input so that I can trigger the LED.
Thank you
Super Contributor
moraali
0
Good evening,
     I am sorry for not replying to you earlier beacuse I was trying to solve the problem by myself until I did not notice the time flew so fast.
Please do not get annoyed. I  had altered the coding , I got the output , but it was not accurate. My supervisor want an accurate answer.
Please help me.
Your help is really being appreciated. Thank you
Super Contributor
moraali
0
Good morning,
  Are you there ? Please help me .
Thank you
Super Contributor
shantanu75
0
It seems your buffer "Global_RX_Buffer"  is not getting clear properly.
Any way You want to retrieve the value 1. One option is
1> take 2nd Array
2> Copy the contents of Global_RX_Buffer to it - Copy only the characters "a to z", "A to Z" or "0 to 9". Befory doing the copy make sure all the contents are 0.
3> Start reading from the end. - First valid caharacter you will get is K follwed by O. The next charracter must be 1.
For example
when you are going to store it in the 2nd Array - It will be like this 321OK
Now Reading from End - KO123. (Ignore the content with values 0x00).
Hope this will help you.
Shantanu Sarkar
Super Contributor
moraali
0
Good morning
   Sorry to disturb you , but I need your expertise
1) Folder_1
=> If you observe , you can see that the value I extracted is not always same . It should only be 1 , not other value, eg:- 3.
=> How should I rectify this problem
2) Folder_2
=> I want to connect the serial cable (null modem) at the Expansion Header. The pin name (ug080.pdf at page 21 )
=> This are the steps I need to do (if wrong pls let me know )
     1) Change the ucf file
          Net fpga_0_RS232_Uart_RX_pin LOC=AA24;
         Ignore this (If I need to change this , what should I change ?)
           Net fpga_0_RS232_Uart_RX_pin IOSTANDARD = LVCMOS33;
      2) Do the MAX2323 board
      3) Connect wire to between MAX2323 and ML401
          Rx   = J6,Pin2
          Tx   = J6,Pin4
          Vcc = Pin 3.3V
          Gnd =Gnd
      4) Connect wire to between MAX2323 and Serial Port.
      I reaaly need your help. Please reply to me as soon as possible
Thank you
