Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
bv
bv
0
Accepted Solution
Why don't the For Loops cause a delay?
Seems like I should see some sort of noticible delay but it zips through this code like the for loops aren't even there...
int main()
    init_platform();
     print("...Hello World...\n\r\n");
	int i, j, tmp;
	print ("Start  Delay\r\n");
	for (i=0; i<1000000000; i++) {
		tmp=i+1;
		for (j=0; j<1000000000; j++) {
			tmp=j+1;
	xil_printf ("Done w/Delay - i=(%d) , j=(%d) , tmp=((%d))\r\n\n", i, j, tmp);
    print("!!! Goodbye World !!!\n\r");
    cleanup_platform();
    return 0;
 Output:
...Hello World...
Start  Delay
Done w/Delay - i=(1000000000) , j=(1000000000) , tmp=((1000000000))
Expert Contributor
gszakacs
Re: Why don't the For Loops cause a delay?
Looks like optimization works :smileyhappy:
There may be some other optimization settings available that won't cut out
the loops.  Otherwise you could use a variable in external memory instead of tmp
to make sure the loop needs to execute every iteration.  I would expect this
loop to take a very long time indeed...
-- Gabor
-- Gabor
bv
bv
0
Thanks Gabor, that's interesting!  When you say external memory what do you mean?  I moved tmp outside the main () { code } to make it a global variable but it still behaves the same.  Is it easy to turn off optimization?
bv
bv
0
Turned optimization off and it now delays as expected.  Still curious what's meant by external memory.  Explanation would be most appreciated.
Bob
Expert Contributor
bassman59
0
"External memory" as opposed to a register. Most counter variables get put into registers for immediate access. Putting it in the memory space occupied by your SDRAM may force the tools to not optimize the access.
Yes, I do this for a living.
bv
bv
0
Doesn't declaring a variable cause, esp outside the subroutine, force this?
Expert Contributor
gszakacs
0
That really depends on the optimizer.  Global optimization allows the compiler to
assume that even global variables do not have side-effects on write as long as
they don't go off-chip (outside the MicroBlaze and its attached BRAM).
It is possible that declaring your tmp variable "volatile" would prevent the loop
from being optimized out.
-- Gabor
-- Gabor
