- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
breakpoint s in a lib not working
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-21-2012 08:33 PM
I just upgraded from SDK 11.5 to 13.4. My application runs fine, but when I set a breakpoint in a library that I link, it never stops at the breakpoint. Breakpoints work fine in the normal code, and I can step into the library and it runs, but when I set a breakpoint, it just runs by it. I have even stepped into a lib function, then I placed a breakpoint 2 lines down, but it doesn't stop.
I'm running out of RAM, not ROM. I have the -g option set in the build file of the lib and the app. Does anyone have any suggestions as to why it doesn't work? Breakpoints worked fine in the lib using SDK 11.5.
Re: breakpoint s in a lib not working
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-22-2012 03:15 AM
if u r runing out of RAM.use external memory SDRAM..genarate ur own linker script by putting starting address od sdram
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-22-2012 08:50 AM
Thank you for your suggestions.
I am running out of external RAM, and I have generated my own linker script. As a matter of fact, it is the same linker script that I used in SDK 11.5.
I am running the SDK 13.4 under Win7 64 bit. Before, when breakpoints worked in the library, I was running 11.5 under XP mode running under Win7 64bit. The library code appears to be running, but all breakpoints placed in the library code are ignored.
