Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Visitor
wangf
0
Accepted Solution
how to input characters from console, why getchar() works not properly?
I try to input character from console, I use standard C function, getchar(), but it does not works properly,
first, it is especially large, second, it can get character back only after I push return key, It is not the way as in standard C.
What is wrong, and how can I input character? Must I use XUartLite_RecvByte() ? I'd like to use standard C functions to make the program easy.
test_id = getchar();
switch (test_id)
    case '1':
     print("input 1\n");
     break;
    case '2':
     print("input 2\n");
     break;
    case '3':
     print("input 3\n");
     break;
    case 'C':
     print("input C\n");
     break;
    default:
     print("wrong enter");
     break;
Expert Contributor
bassman59
0
Re: how to input characters from console, why getchar() works not properly?
Your terminal program might not send the characters until it sees that you've hit ENTER.
-a
Yes, I do this for a living.
Regular Visitor
wangf
0
my terminal program is SecureCRT, and it works well with others embedded system. Also I tried HyperTerminal, it works in same way.
so, do anyone use getchar() successfuly before?  and Must I turn to xilinx uart api?  Thanks.
(My tools and envirorment is Microblaze, EDK92, uartlite v1.0)
Expert Contributor
golson
0
[ Edited ]
I did a search on getchar and EDK.  Other people have been using it according to search in Xilinx Forum.
http://www.xilinx.com/support/answers/29379.htm
and
http://warp.rice.edu/trac/browser/trunk/EDK/LEDs/Demo1.c?rev=56
http://forums.xilinx.com/xlnx/board/message?board.id=EMBEDDED&message.id=876&query.id=392564#M876
http://forums.xilinx.com/xlnx/board/message?board.id=EDK&message.id=4510&query.id=392610#M4510
Try increasing Heap and Stack Size a lot to see if that is the problem.
Message Edited by golson on 12-17-2008 10:17 AM
Regular Visitor
ralfcantnerbosch
Hi together,
I had the same problem.
You can change the buffering behaviour of stdin by calling
setvbuf() before calling getchar();
Example :
setvbuf(stdin, NULL, _IONBF, 0);
for (;;)
  Input = getchar();
  if (Input != EOF)
    xil_printf("%c", Input);
You may omit the line with EOF, I never got that value.
I have tested the code above with XMK, it should work
in a standalone version too.
BTW: Hyperterminal sends each character as soon as you type it.
It does not wait for the <RETURN> key.
Hope this helps
  Ralf
Regular Visitor
wangf
0
Your method works. But it seems that the getchar() function is huge! I decided to use xilinx's api, and deal with all the input myself.
Still, many thanks for your reply.
