Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
ahmadmakhlouf
0
make: *** [microblaze_0/lib/libxil.a] Error 2
greetings every one,
i have recently bright the spartan 3A Video starter kit and i'm building demo project on EDK platform studio 10.1.03 and this error keeps coming on
ERROR:MDT - Failed to add write permission for
   E:\Solution\Camera_Frame_Buffer_Demo\microblaze_0\libsrc\camera_v2_00_a\
ERROR:MDT - Failed to copy
   E:\Solution\VSK_Repository\VSKProcessorIPLib\sw_services\camera_v2_00_a\src\
   to E:\Solution\Camera_Frame_Buffer_Demo\microblaze_0\libsrc\camera_v2_00_a\
ERROR:MDT - Error while running "Copy Files" for processor microblaze_0...
i dont know how to solve it can any one please help me
thank you very much
Expert Contributor
prateek_bhatt
0
Re: make: *** [microblaze_0/lib/libxil.a] Error 2
Please check your permissions on PC. Consult administrator to give you permissions to make changes in files on your PC. Hopefully the problem will be solved...
Best of luck.
Best of luck.
Unlimited in my Limits.
Expert Contributor
rickysu
0
I also have encountered this kind of problems.
Here are my methods:
1. Clean up project and try again. (make sure microblaze_0 is removed when cleaning up)
2. open EDK_SHELL and use chmod -R 777 to that directory.
3. Copy the very necessary project files to another directory and let EDK generate other files.
ar_fasih
0
Hello everybody,
I have still the same problem with this error, !!
EDK 10.1.03
Please help me,
Kind regards,
Fasih
Expert Contributor
prateek_bhatt
0
Hello.
Is there anything before or after this error or this much is the error only.
Please provide full info.
Also try cleaning up the soft project.
Best of luck.
ar_fasih
0
At Local date and time: Fri Oct 02 15:03:32 2009
 make -f system.make program started...
Creating software libraries...
libgen -mhs system.mhs -p xc4vfx20ff672-10   system.mss
libgen
Xilinx EDK 10.1.03 Build EDK_K_SP3.6
Copyright (c) 1995-2008 Xilinx, Inc.  All rights reserved.
ERROR:MDT - Invalid target device 'xc4vfx20'
Done!
windows xp 2002 sp2
hard disk: ntfs
user: administrator
even for the new projec it shows the similar error massage.
thank you for replaying promptly.
regards,
fasih
Regular Visitor
schetz
0
Are you using WebPack? It doesn't support the XC4VFX20.
ar_fasih
0
Dear schetz, there is no EDK in webpack. I'm using EDK.
Thank you
Regular Visitor
schetz
0
I believe EDK still relies on the ISE tools for synthesis and PAR. You need either full-blown ISE or ISE WebPack. Also, did your error change? In your initial post, you talk about file permissions, but more recently, you get an error about an invalid device. Is this new?
