Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
entg888
0
rand() function doesn't do anything on MicroBlaze?
I've been trying to use the random number generator in a C project created by Xilinx XPS SDK 10.1 sp3 but it doesn't output anything.
If i do a
int random = (int) rand();
printf("randomnumber %d", random);
only "randomnumber" is printed and no number follows it.
printf("RAND_MAX = %u\n", RAND_MAX);
returns  2147483647.
I have a system configured with a uartlite as the stdin and stdout, stdlib.h and stdio.h included. Stack and heap size is configured to be 0xEEE.
How do I get the random number generator to function? It's very important to my application, and I'm completely clueless =/ thanks!
Expert Contributor
prateek_bhatt
0
Re: rand() function doesn't do anything on MicroBlaze?
Hello.
Have you initialised your random function before using it.
I think you should use SRAND(0) first before using
random = rand();
Best of luck.
Unlimited in my Limits.
Expert Contributor
prateek_bhatt
[ Edited ]
Hello.
I took a system of UART and microblaze simply.
Software code is mentioned below.
#include "stdio.h"
#include "stdlib.h"
#include "xuartlite_l.h"
main()
int random;
//srand(0);
while(1)
random=rand()%10 + 1;
XUartLite_SendByte (0x84000000, random);
xil_printf("\n\r");
The above code and system is working.
It will be display random numbers between 1 to 10.
Check it out.
Also i found out that srand(0) has nothing do with rand().
So you can ignore it.
Message Edited by prateek_bhatt on 08-20-2009 04:18 AM
Best of luck.
entg888
0
I'm assuming 0x84000000 is the base address of the Uart?
If it is, my terminal is showing a blank screen. xil_printf is working, so it keeps scrolling, but everything else is blank. Could it be other peripherals (like DDR2) interfering with the rand()?
vsiva
You stated that:
That code sequence has nothing to do with rand() itself - you should consider rand as not working only if multiple calls to rand do not return random numbers. From the above code, it looks to me like you just cannot print out integers out on stdout. That probably means that you have insufficient stack/heap. Just try printing out any local integer variable, and see if it comes out.
entg888
0
Thanks guys! I'm not sure what I did, but the rand() function now works fine. Just checking though, roughly how big should the stack/heap be? I'm having some problems with getc(stdin) not pausing the code and allowing user input...
ahofmann
0
rand() seems to need some heap space. Having 256 Bytes heap space or more rand() works reliably. Sadly, this is not mentioned anywhere in the documents, at least not in oslib_rm.pdf as of EDK 10.1 SP3.
Best regards,
Andreas
