- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
xmd% connect mb mdm -- error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-27-2008 02:15 PM
Experiment envirionment: ML501 + ISE/EDK 10.1
After I downloaded the 'bitstream' I launched the ‘XMD’, but the ‘MB’ and ‘MDM’ were not automatically connected. Then, I tried to connect them manually, but when I wrote the command "connect mb mdm", it showed the following error message:
XMD% connect mb mdm
Info:AutoDetecting cable. Please wait.
Info:Connecting to cable (Parallel Port - LPT1).
Info:Checking cable driver.
Info: Driver windrvr6.sys version = 8.1.1.0.Info: WinDriver v8.11 Jungo (c) 1997
- 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811.
Info: LPT base address = 0378h.
Info: ECP base address = 0778h.
Info:Cable connection failed.
Info:Connecting to cable (Parallel Port - LPT2).
Info:Connecting to cable (Parallel Port - LPT3).
Info:Connecting to cable (Parallel Port - LPT4).
Info:Connecting to cable (Usb Port - USB21).
Info: Driver file xusbdfwu.sys found.
Info: Driver version: src=1027, dest=1027.
Info: Cable PID = 0008.
Info: Max current requested during enumeration is 280 mA.
Info:Type = 0x0605.
Info: Cable Type = 3, Revision = 0.
Info: Setting cable speed to 6 MHz.
Info:Cable connection established.
Info:Firmware version = 1028.
Info:File version of C:/Xilinx/10.1/ISE/data/xusbdfwu.hex = 1028.
Info:Firmware hex file version = 1028.
Info:PLD file version = 0012h.
Info: PLD version = 0012h.
JTAG chain configuration
Device ID Code IR Length Part Name
1 f5059093 16 XCF32P
2 59608093 8 xc95144xl
3 0a001093 8 System_ACE
4 22896093 10 XC5VLX50_U
MicroBlaze Processor Configuration :
Version............................7.10.b
Optimization.......................Performance
Interconnect.......................PLBv46
MMU Type...........................No_MMU
No of PC Breakpoints...............1
No of Read Addr/Data Watchpoints...0
No of Write Addr/Data Watchpoints..0
Instruction Cache Support..........off
Data Cache Support.................off
Exceptions Support................off
FPU Support.......................off
Hard Divider Support...............off
Hard Multiplier Support............on - (Mul32)
Barrel Shifter Support.............off
MSR clr/set Instruction Support....on
Compare Instruction Support........on
ERROR: MicroBlaze is under RESET. Check if the Reset input to MicroBlaze and it
s Bus Interfaces are connected properly
UNABLE to STOP MicroBlaze
XMD%
Has someone met the same error before? Does this mean I should manually change the RESET signal of Microblaze?
Thanks!
Re: xmd% connect mb mdm -- error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-29-2008 02:34 AM
If you have no clock (for unrelated reasons) this will happen. Usually designs hold reset off until the clk gen (DCM, PLL) locks.
You don't need to change the reset, but make sure polarity is correct.
That said, needed mdm connections change when migrating from older (opb_mdm 2.0a / mb 6.0) to newer debug modules. I haven't changed to PLB 4.6.
-Jerry
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-29-2009 05:22 AM
I had a similar problem (ERROR: ... is under RESET) and didn't understand how to check that my clocks were all set properly.
When looking at my "Ports" connections in the "System Assembly View" I couldn't see the clock ports: in order to see them I had to change the "Filters" applied to my display. I enabled the display of all signals and I managed to modify the clock signals connections and it worked just fine!
G.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-28-2011 12:10 AM
i check all clock ports also then also same issue wat to do
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-29-2011 10:48 AM
You may want to check the polarity of the reset on your board and compare it to what you have in your system. It is likely that there is a conflict here causing Microblaze to be held in reset.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-22-2012 04:56 AM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-31-2013 12:50 PM
Thanks guys-- been stuck on this problem for two days. Had to re-assign the reset polarity and change the clk in my ucf file to 100MHz. Kudos to you all-- again, much thanks.
