Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
cyberwizzard
0
Re: Device Tree for c67x00
I solved my problem, see the thread I linked before for information and a patch to "fix" the Cypress driver to use the DTS properly.
pierre_usb
0
Ok thanks for the "patch".
I succeeded to use C67x00 driver but without to use the device tree. I will try to use the "patch" to use device tree support.
Have you fixed your interrupt error?
I have a very slow USB bandwidth... Have you problems with reading, writing or bandwidth?
Best regards.
Pierre
cyberwizzard
0
The interrupt error was due to unconnected pins which prevented the clearing of the interrupt.
The bandwidth is not extremely high (due to the lack of DMA, I think I read that somewhere) but enough to drive a USB headset for example.
pierre_usb
0
Ok,
The bandwidth for me was 600 kbytes/s before I reduced the value TOTAL_FRAME_BW  in the driver from 12000 to 4096 because I had writing errors... After that, I obtained a bandwidth of 120 kbytes/s but without reading or writing errors.
Pierre
rekikamal
0
hi
I have the same problem as you
I'm working with the ML507 FPGA with power pc processor
Im trying to use the usb port using the linux2.6 kernel
and i have problem with the generator of the device tree
could you please give me some information how make the usb port working with CYPRESS c67x00
thanks
amal
mikertetc
0
I am also working with the C67x00 on the microblaze. I saw your post concerning unconnected interrupt pins. Could you tell me which pins were unconnected? I am seeing pretty much the same problem and would like to point the way for the hardware guy.
hooligan1989
0
I have the same problem as you do.
I tried almost everyway I found on the forum, although there are not many.
Have you solved the problem?
Thank you!
Xiangyu
