- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Device Tree for c67x00
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-26-2009 09:42 AM
one of my big problems when developing for the ml403 is that I never managed to make the USB to work. In particular, I never managed to make the c67x00 driver to work in Linux, although I managed to made the usb keyboard example code(from EDK) to run together with the SystemACE ( they share some lines ) with no OS. One of the reason for upgrading to arch=powerpc has been this. I little question to begin with ( I might come with more of this later ) is, how should the device tree should look so to load the c67x00 hcd driver? I have tried with something like:
xps_epc_0: usb@80800000 { compatible = "cypress,c67x00"; interrupt-parent = <&xps_intc_0>; interrupts = < 0 2 >; reg = < 0x80800000 0x10000 >; xlnx,family = "virtex4"; } ;
I have tried playing with some of the things there, with no luck.I managed to load it before with the xparameters.h , but I don't that much how device-trees work regarding to this.
This is for me one of the parts I liked less from using the ml403, the lack of support for the USB. Of course there is an Xapp to make it work,but alone, without the System_Ace and that is for some us useless. If I manage to make it work I wouldn't mind to write a document about it ( hw/sw instructions) since it doesn't seem to be any information on the whole internet about it.
Any ideas?
Thx!
Re: Device Tree for c67x00
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-26-2009 10:26 AM
What does "no luck" mean? Does linux report anything about USB when it comes up? I've not used that USB chip before, but I have used another vendor's hooked up via the EPC, and your .dts entry looks similar to what I used - assuming "interrupts" is set correctly.
Terry
[ Edited ]- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-29-2009 02:06 AM - edited 06-29-2009 06:01 AM
With no luck I mean that the driver doesn't load. I am using a merged branch between DENX+Adeos 2.6.29.4 (Xenomai) and Xilinx development. This is my boot sequence:
Linux/PowerPC load: console=ttyUL0 root=/dev/xsa2 noinitrd rootfstype=ext3 rw
Finalizing device tree... flat tree at 0x5e9300
Using Xilinx Virtex machine description
Linux version 2.6.29.4 (xxx@xxx) (gcc version 4.2.2) #6 PREEMPT Fri Jun 26 17:47:04 CEST 2009
Zone PFN ranges:
DMA 0x00000000 -> 0x00004000
Normal 0x00004000 -> 0x00004000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00000000 -> 0x00004000
MMU: Allocated 1088 bytes of context maps for 255 contexts
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: console=ttyUL0 root=/dev/xsa2 noinitrd rootfstype=ext3 rw
Xilinx intc at 0x81800000 mapped to 0xfdfff000
PID hash table entries: 256 (order: 8, 1024 bytes)
clocksource: timebase mult[d55555] shift[22] registered
I-pipe 2.6-02: pipeline enabled.
Console: colour dummy device 80x25
console [ttyUL0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 60644k/65536k available (3808k kernel code, 4828k reserved, 144k data, 244k bss, 152k init)
SLUB: Genslabs=10, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 593.92 BogoMIPS (lpj=296960)
Mount-cache hash table entries: 512
net_namespace: 520 bytes
bio: create slab <bio-0> at 0
XGpio: /plb@0/gpio@81460000: registered
XGpio: /plb@0/gpio@81440000: registered
XGpio: /plb@0/gpio@81420000: registered
XGpio: /plb@0/gpio@81400000: registered
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
I-pipe: Domain Xenomai registered.
Xenomai: hal/powerpc started.
Xenomai: real-time nucleus v2.4.8 (Lords Of Karma) loaded.
Xenomai: starting native API services.
Xenomai: starting POSIX services.
Xenomai: starting RTDM services.
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
fuse init (API version 7.11)
msgmni has been set to 118
io scheduler noop registered
io scheduler anticipatory registered
84000000.serial: ttyUL0 at MMIO 0x84000003 (irq = 16) is a uartlite
brd: module loaded
loop: module loaded
xsysace 83600000.sysace: Xilinx SystemACE revision 1.0.12
xsysace 83600000.sysace: capacity: 4001760 sectors
xsa: xsa1 xsa2 xsa3
Xilinx SystemACE device driver, major=254
xilinx_emaclite 81000000.ethernet: Device Tree Probing
xilinx_emaclite 81000000.ethernet: MAC address is now 2: 0: 0: 0: 0: 0
eth0 (): not using net_device_ops yet
xilinx_emaclite 81000000.ethernet: Xilinx EmacLite at 0x81000000 mapped to 0xC5080000, irq=18
Generic platform RAM MTD, (c) 2004 Simtec Electronics
xilinx-xps-spi 81818000.xps-spi: at 0x81818000 mapped to 0xC503A000, irq=19
usbmon: debugfs is not available
usbcore: registered new interface driver cypress_cy7c63
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
Device Tree Probing 'i2c'
81620000.i2c #0 at 0x81620000 mapped to 0xC50A0000, irq=20
81600000.i2c #0 at 0x81600000 mapped to 0xC50C0000, irq=21
usbhid: v2.6:USB HID core driver
TCP cubic registered
kjournald starting. Commit interval 5 seconds
EXT3 FS on xsa2, internal journal
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
VFS: Mounted root (ext3 filesystem) on device 254:2.
Freeing unused kernel memory: 152k init
The device-tree script doesn't generate anything for the cypress so I added it myself with some references that I found in maillists of linuxppc-dev. For me it clearly doesn't seem to load. I have given the interrupt 0 to the hpi interrupt from the cypress. The signals to the FPGA are muxed based in some glue-logic I found in the ML403 reference design.
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-29-2009 03:30 AM - edited 06-29-2009 03:33 AM
One more thing. When I managed to load the driver in PPC, I had something like:
* Cypress USB C67x00 shortcut macro for single instance
#define XPAR_C67x00_USB(num) { \
.name = "c67x00", \
.id = num, \
.num_resources = 2, \
.resource = (struct resource[]) { \
.start = XPAR_C67X00_USB_PRH##num##_BASEADDR, \
.end = XPAR_C67X00_USB_PRH##num##_BASEADDR + 0xf, \
.flags = IORESOURCE_MEM, \
.start = XPAR_OPB_INTC_0_SYSTEM_USB_HPI_INT_PIN_INTR, \
.end = XPAR_OPB_INTC_0_SYSTEM_USB_HPI_INT_PIN_INTR, \
.flags = IORESOURCE_IRQ, \
.dev.platform_data = &(struct c67x00_platform_data) { \
.sie_config = C67X00_SIE1_HOST | C67X00_SIE2_PERIPHERAL_A, \
.hpi_regstep = 0x02, /* A0 not connected on 16bit bus */ \
But I don't know that well how that should translate to .dts notation...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-30-2009 03:29 AM
Well, I will answer this question myself. Looking into the driver i have found that there is no openfirmware (OF) support for this so the system is not going to load c67x00 from the device-tree without it. I am working on a patch for it right now, whenever I have it working I'll try to publish it for review.
If someone is thinking about doing it ( or has done it), please let me know.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-28-2011 06:01 AM
I try to modify the dts file because, like you, I try to use the CY7C67300 driver but the controller is not recognised by Linux.
Is your patch done?
Have you information about the .dts file?
How can I know the port number between the Cypress controller and the interrupt controller (xps_intc)? It's not indicated in the mhs file...
Thank you.
Pierre
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-28-2011 06:35 AM
yes, I got this working some time ago. However I don't have the patch now and I won't have until next week( out-of-the office ATM). One reminder here in 1.5weeks and I'll try to get it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-28-2011 06:38 AM
Ok thank you very much
Pierre
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-09-2011 06:53 AM
I begin to modify the c67x00 driver for ".dts" file but i have some problems with the interrupt.
Have you found your patch?
Thank you
Pierre
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-10-2011 02:54 AM - edited 06-10-2011 02:55 AM
I am trying to use the Cypress USB controller in host mode as well. The current kernel does not support DTS initialisation of the c67x00 driver - you can compile it but it gets never loaded. The patch everyone seems to implements bypasses the DTS init and just hardwires the driver to start.
I got a more elegant way by modifying the driver to accept parameters from the DTS and register itself with the platform loader to get started like other drivers. While that seems to work, I also have issues with the interrupt on the Cypress/xps_epc device.
In my case it seems to keep firing events. Switching from edge to level triggers does not seem to do anything. Does anybody have a solution?
BTW my own thread is over here: Use ML605 Cypress USB controller as EHCI host in linux
