Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Visitor
fk5747
0
Accepted Solution
linux driver : problem with rmmod
hi everybody
I am getting started with linux driver development and I want to test how to insert a driver into linux kernel. I've built and run the linux kernel on MicroBlaze on my custom spartan3e board and every thing works fine.
my driver is so simple :
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/init.h>
MODULE_LICENSE("BSD/GPL");
static int hello_init(void) {
  printk("KERN_INFO "Hello : init is working good!");
  return 0;
static void hello_exit(void) {
  printk("<KERN_INFO "Hello : exit is working good!");
module_init(hello_init);
module_exit(hello_exit);
after compiling the driver I insert it using insmod and it works fine. but then  I cannot remove it
# rmmod hello
rmmod: chdir(/lib/modules): No such file or directory
Am I using rmmod correctly?
I would appreciate any suggestions. thanks in advance.
Regular Visitor
madhuba
0
Re: linux driver : problem with rmmod
Please do "lsmod" to check if the module was really inserted or not.
Madhubala
Regular Visitor
fk5747
0
yes, it has inserted correctly! it allocates major and minor numbers too!
now, what else?
Regular Visitor
madhuba
Hi ,
The solution to this problem is please create the directory /lib/modules and then /lib/modules/2.6.39
rmmod is looking for this and since its not finding its throwing the error.
Madhubala
Regular Visitor
fk5747
0
thank you
It works :)))
