Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Contributor
beandigital
0
menuconfig
I am looking at developing a SATA driver. When I use menuconfig with version 3 of the kernel all of the SCSI driver options are gone. Is there a way to get them back?
Jon
Super Contributor
norman_wong
0
Re: menuconfig
I've no problems with accessing the SCSI menu so far. I am using the tree from linux-xlnx GIT, build3-trd tag. On my platform:
make ARCH=arm xilinx_zynq_defconfig
make ARCH=arm menuconfig
Regular Contributor
beandigital
0
Re: menuconfig
I'm using Microblaze, don't know if that matters.
Super Contributor
norman_wong
0
Re: menuconfig
Which default config are you using? From what I can see in the Xilinx GIT, CONFIG_BLOCK was removed from most of the configs in 2010-08-14. The SCSI and lot other stuff was dependent on this config setting. The xilinx_mmu_defconfig looks okay. Just guesses.
Regular Contributor
beandigital
0
Re: menuconfig
I'm using the sp605 config and then altering it to match my hardware. Not being a Linux expert can you tell me what determines the menu items when menuconfig is used?
Super Contributor
norman_wong
0
Re: menuconfig
I'm no expert either and I'm not familiar with the Microblaze platform. My comments are from tracing the Kconfigs in the kernel at the Xilinx GIT.
arch/microblaze/Kconfig - Config template for all microblaze boards.
drivers/Kconfig - sourced by above
drivers/scsi/Kconfig - sourced by above. Note depends requirements.
arch/microblaze/configs/sp605_le_defconfig
- Board specific. Order of values listed should match definitions in arch/microblaze/Kconfig. You could try directly enabling BLOCK by changing the line
# CONFIG_BLOCK is not set
to
CONFIG_BLOCK=y
The xilinx_mmu_defconfig seems to okay with setting it. There should be a ""Enable the block layer"" in the menuconfig but I can't seem to find an "source block/Kconfig". Probably in another Kconfig file.
Regular Contributor
beandigital
0
Re: menuconfig
I will try experimenting and see what I can do.
Jon
